Old 02-09-2020, 09:56 AM   #1
Ed in Maine
Default 1931 Victoria Door Hinge Mirror
I want to put an outside mirror on my Victoria. These cars use an oversized hinge pin (0.279). Does anyone have a source for these oversized pins in SST that are longer to accommodate a mirror? I have purchased the mirror but the hinge pins that come with it are too small. Also, has anyone drilled out the bracket on the mirrors to receive the larger diameter pins? Is there enough metal in the bracket for the larger pin? Thanks for your help, ED
Ed in Maine is offline   Reply With Quote
Old 02-09-2020, 10:37 AM   #2
jw hash
jw hash's Avatar
Default Re: 1931 Victoria Door Hinge Mirror
Ed
I use 32 oversize stainless pins. they are longer then the Victoria. I also turn the end of the pin down and put a 1/4" acorn nut on the bottom
jw hash is offline   Reply With Quote
Old 02-09-2020, 11:50 AM   #3
Pmsqrd
Pmsqrd's Avatar
I bought a set of outside mirrors from Berts. Steve sends the pins you need for a Vic. The mirrors will need to have the hinge mounting hole enlarged to accept the slightly bigger pin.
Pmsqrd is offline   Reply With Quote
Old 02-10-2020, 09:46 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
On my Victoria, the pin holes have been drilled to 0.31" diameter and roll pins installed in the lower door hinges. Being springs, roll pins accommodate stock and oversize holes nicely. I cut the heads off of the stock hinge pins leaving about 0.13" of the pin under each head. The heads are secured in place with JB Weld.
External mirrors are attached to the upper hinge on each door. The hinge pin holes in both door hinges and mirrors were opened to 0.31" diameter. In lieu of hinge pins, I use 0.312 hex head bolts, and capped the heads and nuts with chrome acorn covers. Holes in each door hinge were drilled & tapped to accommodate the set screws of each mirror. This setup works very well, and its neat looking.
Bob Bidonde
Old 02-10-2020, 02:21 PM   #5
Tom Endy
Tom Endy's Avatar
Attached article may be of help.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 02-10-2020, 07:58 PM   #6
Bud
Bud's Avatar
I have found on my '31 S/W town sedan that I need a longer mirror arm than the reproduction mirror arm pictured on this thread. That mirror arm is 5.5" from the hinge pin center to the hole for the mirror head. I measured my sedan and found the rear of the car is wider by 1.5" than at the door where the mirror would be. The mirror arm length to get adequate visibility (to me) is more like 8.0". Would others agree?
Also, I have not found a mirror arm this length that is reproduced.
Bud is offline   Reply With Quote
