Old 12-16-2019, 11:25 AM   #1
Kentmac
Default Transmission gear/shaft question
In the process of working on the transmission in my model A and need some advice. I am replacing all the bearings and discovered the main shaft (not gear shaft) has some scoring so I ordered a new main shaft and received it from Snyders. The issue I am having is that the gears were difficult to install on the main shaft and do not slide freely back and forth. I put some grease on the shaft and can move the gears by hand but I think they are too tight. Any advice would be appreciated
Kentmac is offline   Reply With Quote
Old 12-16-2019, 11:30 AM   #2
ryanheacox
ryanheacox's Avatar
Default Re: Transmission gear/shaft question
You do want a reasonably tight fit. Can you slide them back and forth by hand? Someone has a write-up that states the gears should just barely slide down the shaft if it is stood up vertically.
Edit: it is on Jim Mason's website. http://jmodela.coffeecup.com/xmissionrebuild.html
ryanheacox is offline   Reply With Quote
Old 12-16-2019, 11:36 AM   #3
Kentmac
The gears do not slide easily at all, I can move them but with quite a bit of effort.
Old 12-16-2019, 11:37 AM   #4
rotorwrench
rotorwrench's Avatar
They should slide but have no rocking play so they have to be a close fit. If they won't slide by hand push fit then the shaft may be a bit oversized. That's fine if gears are worn but not so good if gears have no wear. It's a good idea to check the dimensions the best you can and see where the clearance is the tightest. If it's on the OD of the shaft then that should be no problem but if it's in the splines then that could be a problem.
Old 12-16-2019, 01:58 PM   #5
Tom Endy
Tom Endy's Avatar
There is a Ford service bulletin that states there should be .002 clearance between the shaft and the two slider gears. The bulletin went on to say that when replacing any one of the three parts, they all should be replaced as a matched set. One would think that Henry Ford hired Henry Aldridge to sit in the stock room and match up shafts and gears. It was also a good way to increase parts sales. Whatever was the case, Henry Aldridge would have retired years ago, and today there is no such thing as a matched set from a supplier.
When I put a transmission together I check to make sure the slider gears move on the shaft freely and without a lot of slop. It is very difficult to get a match with reproduction parts.
Before I would buy a reproduction main shaft I would have the original that works well with the slider gears repaired. The worn front end bearing surface can be machined down and hardened drill bushings of the proper size pressed on. This is not a difficult machine shop process. Jim's Automotive Services in Costa Mesa, CA 714-546-2969 provides this service.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 12-16-2019, 02:01 PM   #6
100IH
If you want to loosen them up or indicate where the rub is, put a very small amount of lapping compound ( fine or extra fine) on the shaft and slide one gear at a time back and forth on the shaft - this is done with the splined shaft and the gear on the bench, not in the housing. Do all of the gears one at a time. Leave no compound after, wash in solvent and soap after the solvent.
100IH is offline   Reply With Quote
Old 12-16-2019, 03:08 PM   #7
Jim Mason
Jim Mason's Avatar
Lube with your xmisson lube, stand the shaft on end. gear should slide down by its own weight or with light finger pressure.
I have a mediocre articke on my site, Tom Endy has a better one somewhere.
Jim Mason
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 12-16-2019, 03:22 PM   #8
J Franklin
J Franklin's Avatar
I think as long as they can be moved with drag you will be all right. Too loose causes problems with popping out of gear.
Old 12-16-2019, 03:25 PM   #9
Kentmac
Thanks for all the replies, I tried moving the gears back and forth on the shaft but did not have any luck. I called Snyder's and they acknowledged that there were some problems with some shafts. They are going to send me another and test it with gears before they send it out. I had another suggestion that might also have worked and that was to use a brake cylinder hone, as I didnt have one, I opted for the new one, hopefully it will work.
Old 12-16-2019, 04:13 PM   #10
Tom Endy
Tom Endy's Avatar
See attached article.
Tom Endy
Old 12-17-2019, 01:19 AM   #11
AGBill
I had the exact same problem with a new shaft that I purchased from Snyders. The solution for me was to mount the shaft in a small lathe and used some medium grit emery cloth with no lubricant. I spun the shaft and looped the emery cloth around it and removed about 0.002-0.003. The gears then slid on the shaft freely with no problems.
AGBill is offline   Reply With Quote
Old 12-18-2019, 11:54 AM   #12
macdonge
macdonge's Avatar
Ditto what you said AGBill. I received a new shaft from Snyders yesterday and there was no way the low/reverse or second/high gears would even go on it (without a hammer). Took it to a friends place this morning, chucked it up in his lathe and after 15 minutes or so with the emery cloth (sneaking up on the proper fit) had them both on the shaft and sliding perfectly.
macdonge is offline   Reply With Quote
Old 12-18-2019, 02:26 PM   #13
AGBill
Snyders - if you read these posts, you need to do the following:
1. Take all the shafts in stock to a local machine shop and have them remove a few thousandths off the outside diameter of the shaft. Bring along an original sliding gear that the shop can use as a (go/no go) gage for the proper diameter. After the shafts have been modified, put them back on the shelf for sale to customers.
2. Change the existing fabrication drawing for the shaft by reducing the drawing maximum dimension for the outside diameter by 0.003 - 0.004 thousandths. This will prevent future batches of the shaft from having the same problem.
Keep your customers happy!
Old 12-18-2019, 02:56 PM   #14
ursus
On the other hand, it is possible that the vendors' main shafts are sized to match the gears they sell and are not to the original Ford specs.
Also, I have found that even a new and unused NOS Ford main shaft may well be too loose when mounted with used original Ford gears. In that case, the slightly oversized repop main shaft is a good thing because you can chamfer it down to achieve a close fit for better performance. Call it making lemonade from lemons.
I have also found that original Ford gears may not mix well with repop gears - noisy or jumping out of gear - and it is usually best to install all the gears in one case with one source or the other.
ursus is offline   Reply With Quote
Old 12-18-2019, 07:06 PM   #15
rotorwrench
If they are oversized then that would be handy with an old worn set of gears but they should be marked as such. This has been a problem with some reproduction parts over the years. It boils down to the manufacturer's quality control.
Old 12-18-2019, 09:27 PM   #16
J Franklin
J Franklin's Avatar
One size (can) fit all!
Old 12-20-2019, 02:14 PM   #17
Kentmac
Got my replacement shaft yesterday and installed it today. Quick response from Snyder's.
