12-06-2019, 11:56 AM | #1 |
Mart's Crusty Flatty Teardown Pt6. Studs!. Get 'em out!
Having successfully got the valves, crank, pistons, cam and lifters out, in this episode I turn my attention to the studs. I show a method that seemed to work well on this motor. This may not work for all motors. Your results may vary. Will vary more likely.
See how it went: https://youtu.be/2MEvSNArcic Mart. |
12-06-2019, 01:02 PM | #2 |
Re: Mart's Crusty Flatty Teardown Pt6. Studs!. Get 'em out!
I have to be honest, your English accent makes that job very calming. I enjoyed it. Thanks for posting! It's also good to put a face to a name. Keep up the good work.
12-06-2019, 01:53 PM | #3 |
You did good on that job...i usually end up with around 3 broken studs...
Time for step by step rebuild video now !! |
12-06-2019, 03:30 PM | #4 |
Thanks Mart, I'm going the use the hammer to get the rest of mine out, just have to wait until spring as my block is in a portable garage and its 30 degrees and snowing at the moment. I also am going to try and weld a nut onto the three broken studs to get them out.
12-06-2019, 03:42 PM | #5 | |
I have had further stud removal experience which did end up with some breakages. I also used heat. Re the welding on of the nut. Drill right through the stud remnant first. That worked for me once. I might do a further video showing it not going so well. Might, mind, no promises. Mart. |
12-06-2019, 03:53 PM | #6 |
12-07-2019, 07:26 AM | #7 |
Mart you are the best. Really great videos.
12-07-2019, 11:01 AM | #8 |
Mart,
Those videos are the “go to” ones for anyone starting to disassemble their first stuck flathead. Now if I could just find a young apprentice to teach on the ten or so that I have. Ralph |
