Old 11-28-2019, 10:20 PM   #1
keyswitch1
Arrow Install generator
It seems like every time I install a generator lately I have trouble lining up the hole. Any body have an easy way they would like too share ?? Thank you for help. Fifty years ago I never had a problem . Please do not say old age
keyswitch1 is offline   Reply With Quote
Old 11-28-2019, 10:30 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Install generator
Ok I won't say it.
Old 11-28-2019, 10:44 PM   #3
Bill G
Bill G's Avatar
Fifty years ago you could probably hold the generator still and even jockey it around with one hand while simultaneously lining up the bolt. I seem to have less arm strength than I did 50 years ago, so I suspect I am not alone!
-Bill G
Member of Walla Walla Sweet A's Model A Club
Bill G is online now   Reply With Quote
Old 11-29-2019, 12:11 AM   #4
Mike Peters
Mike Peters's Avatar
You could put an undersized bolt or tapered punch just in one hole as a guide, the feed the half inch generator bolt in the other hole, remove the punch, and then feed the half inch bolt through the second hole.
Mike Peters is offline   Reply With Quote
Old 11-29-2019, 05:05 AM   #5
old31
I have the same problem and its frustrating to spend so much time on 1 bolt.
So I got a 10" rod a little smaller than bolt size. I beveled a v on one side. The v side is then put in from the firewall side till the point comes out of the radiator side. This will align the gen to the bracket.
I then slowly pull out the rod as I slowly slide in the generator bolt from the radiator side.
Old 11-29-2019, 05:10 PM   #6
keyswitch1
I got it done!
Old 12-01-2019, 09:27 AM   #7
ericr
ericr's Avatar
I assume you already have the belt on and we had a discussion some time ago how a lot of belts we are using are actually the wrong circumference. I can't believe that replacing a belt originally was such an ordeal.
But yeah we lose hand strength as we get older. I need a tool to open the cap on my prune juice bottle.
ericr is offline   Reply With Quote
Old 12-01-2019, 11:30 AM   #8
Purdy Swoft
Purdy Swoft's Avatar
There is one bolt that attaches the generator pulley . It is so much easier to install the belt when the pulley is removed . I slip the belt in the groove of the pulley and only need to move the pulley in one direction to slip the pulley back over the armature of the generator, reinstall the bolt and the pulley and belt are back in place . . Magnesium will help prevent muscle loss .
Old 12-02-2019, 12:10 PM   #9
37 Coupe
37 Coupe's Avatar
I cannot believe sometimes the amount of time I have spent on a single cotter pin.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 12-02-2019, 12:39 PM   #10
keyswitch1
Do not tell any body but the person I bought it from had the lower radiator pipe up to high ! I guess it would have been beater if I saw it earlier !
Old 12-02-2019, 02:11 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
If you remove the generator pulley bolt, be sure it's real tight when you finish the job.
I saw one come loose at the national meet about 10 years ago, and it broke the water pump, tore up the radiator, and dented the hood.
Old 12-02-2019, 03:13 PM   #12
old31
Oh boy, what is wrong with us. WOW.
"magnesium" "muscle loss" "can't find the hole" "jockey it with one hand" "less arm strength" "prune juice" "lost hand strength"!
I just can't read this anymore, I have to go take a nap.
Old 12-02-2019, 07:30 PM   #13
Mulletwagon
Mulletwagon's Avatar
Most of us can pull a rear axle or drop a trans just like we did 50 years ago - just takes longer to recover.
Mulletwagon is offline   Reply With Quote
Old 12-02-2019, 11:00 PM   #14
Purdy Swoft
I haven't had a generator pulley come loose yet . I did once wring off a generator pulley bolt . smiley face
Thread Tools
Display Modes
