Old 11-28-2019, 11:52 AM   #1
bjwsr1935
Default timng gear from a camshaft
How do you remove the timing gear from the camshaft? Its a 37 ford v8 flathead. Also looking to replace the gear but having difficuilty finding one to purchase
bjwsr1935 is offline   Reply With Quote
Old 11-28-2019, 11:55 AM   #2
bjwsr1935
Question Re: timing gear from a camshaft
how do you remove the old timing gear from the lower camshaft from a 37 Ford v8 flathead? Aso looking to replace it but having difficuiting finding one.
Can you help?
Old 11-28-2019, 11:56 AM   #3
KiWinUS
KiWinUS's Avatar
Default Re: timng gear from a camshaft
Presses off & back on. Check with Barnfind08 here on fordbarn- Fred Wilmer he has gears.
Cheers
Tony
Old 11-28-2019, 03:08 PM   #4
mfirth
Did you try Vanpelt Sales...for a new one?
mfirth is offline   Reply With Quote
Old 11-29-2019, 07:14 AM   #5
Mac VP
Mac VP's Avatar
I assume that your request was for the timing gear on the camshaft. For 1935-38 cams that gear was pressed onto the camshaft. Those were fiber gears with a steel center bore. There’s a small notch on the steel center which must align with a comparable notch on the cam. We have original style fiber gears in standard, and a couple oversizes (.003” and .005” I believe). We don’t have the press on gears available in aluminum at this time. Just contact us after the holiday break if you want to order one.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 11-29-2019, 03:22 PM   #6
v8nut
v8nut's Avatar
Be very careful when you press the timing gear back on. The registration mark or index mark on my 1935 camshaft is not easy to see. See picture below. My engine rebuilder had an apprentice assemble my camshaft and he must of just guessed where to press the gear back on. It was way off and of course the engine did not run. It was not a lot of fun to fix as you can imagine.
v8nut is offline   Reply With Quote
