Old 09-10-2019, 09:06 AM   #1
HarveyWallbanger
Default LOTS of 1941-1948 Sedan Parts, New, NOS, Used, and Affordable!
City: Greeley
State: Pennsylvania
Price: Varies
We have a 1941 Ford Tudor project in our shop, and NOW the owner is convinced that it is too far gone to restore. I'm listing all of these parts to help the owner recoup some of his money.
ALL LISTED PRICES ARE WHAT WAS PAID, OR WHAT YOU WOULD HAVE TO PAY TO BUY NEW TODAY.
MAKE ANY OFFER FOR WHATEVER YOU NEED. EVERYTHING IS VERY NEGOTIABLE.
FREE DELIVERY TO HERSHEY. Shipping at additional expense.
All parts are located at
Nostalgic Restorations
244 Route 590
Greeley, PA 18425
Call Mark at 570-685-2680
I have lots of photos, and can send upon request. Parts with part numbers are all in original packages.
Interior and Glass
11A-7022296 … 41-42 Closed Car Vent Window Glass Edge Seal - Bob Drake $17.49
11A-7011508 … 41-48 Floor Board Seal Mac’s $24.95
11A-7003110-A … 41-48 Windshield Rubber Seal, Mac’s $58.25
B773540 … Glass edge weather strip, $120
A45963X … Glass Bedding, 10’ x 1/16” (holds glass to frame), Mac’s $19.90
11A-7023402-K … 41-48 Vent Window Regulator Rebuild Kit - Bob Drake $40
78-7043724-BS … 37-48 Fordor Sedan Upper Door Seal Kit, Vintiques $35
41 Horn button center ring, $10
41 Front Window Crank handles, Vent Window handles, escutcheons, $75
41-48 Long door front window channel pair $50
41 Gas Pedal, $15
41-48 Interior mirror, $25
41 Closed car wiper motor, $50
41-48 Front floor pan, $178.99
Front seat frame $200
Rear seat frame $100
Exterior
11A-17772/3 … Front Bumper Arm Grommets, Passenger, 41-48 - Mac’s $11.49
11A-17792/3A … Rear Bumper Arm Grommets, All styles, 41-48, Mac’s $11.49
21A-8208K … 41-48 Lower Deflector Seal, $7.95
11A-167405 … 41-48 Ford Hood Seal, $9.99
01A-8211 … 40 Deluxe Lower Grille Chin Pan, Mac’s $74.99
41 Ford Hood Latch Assembly, $85
Hood Latch Dowel 19.95
Hood Latch Dowel Assembly $35
41 Ford trunk striker and support $95.94
41-48 inner fenders $50
‘41 aftermarket running boards $390
Mechanicals
18-11057 … Starter Brush Set, Mac’s $15.98
5GA-6038 Engine Front Support Insulator Assembly - Passenger 6 Cylinder 41-47 OEM $60
1GA-12200 … Distributor Rotor for 6 Cylinder, Mac’s $7.95 (have two)
375188 … Fuel pump diaphragm - Mac’s $13.85v
Ford single exhaust tail pipe tip, $14
Gas tank $239, sending unit $39.95, sending unit cover $15.49, filler neck $59.99, brackets $52.50 (406.93)
Lights and Electrical
41 Tail light gasket, body to light, $6.99
46-48 tail light grommet? $4
41 Tail light Housing, $35 each
41 Tail light lens, $12.50
41-48 Ford 21 Piece Light Bulb Kit, $35.49
41 Parking Lights Set, $85 (with 11A-13082-G … Parking Light clear lens $12.50 each, 11A-13217 Parking light rubber pad, $9.95)
Parting out the rest of the car - rusty Tudor, six cylinder that turns over (runs on can, supposedly), radiator holds water
Sunvisors with brackets
41 Grille Parts, two centers - one steel, one plated, both outers.
41 NOS Front Fender Tops
41 Ford bumpers, bumper guards, overrider
Handmade 41-48 Sedan trunk floor - 5 pieces
Headlights complete $60 each
Extra headlight bulbs $25
MAKE A REASONABLE OFFER FOR ALL OF YOUR WANTS AND NEEDS.
Still to be priced out:
I would like to sell the rest of the car, and I’m not entirely against parting it out.
It is a Tudor with a six cylinder that turns over (runs on can, supposedly) and the radiator holds water. This would be an ideal Nostalgia Stock Car, or at worst, a donor for a better project.
If it does come to parting it out, one buyer would need to buy quite a bit of parts so I’m not stuck with a shell that won’t move.
Good roof $200
Hood $125
Fenders $25
Window regulators $50 each
Entire door or skins $75 each
garnish moldings $30 each, (does not have the rear window)
Rear window can be cut out for a chopped car $75
Can cut windshield out $75
Cowl can be cut anywhere you want $200
Exterior handles $30 each
Latches
Glass
seat springs
solid floor from front foot area to front edge of trunk
lots of body skin for patches
Other misc. Mechanicals
Chassis
The dashboard and driver compartment are pretty nice, and I’m considering hanging on to them for a little while in case a hot rod comes up that needs something like that. But, it is complete, steering wheel is in presentable shape, column is real nice, dash has amateur restoration work, and the plastic horizontal trim has a crack under the gauge cluster.
MAKE OFFERS AND CALL MARK AT 570-685-2680.
Last edited by HarveyWallbanger; 09-19-2019 at 10:15 AM. Reason: Reorganization, and added parts and prices.
HarveyWallbanger is offline   Reply With Quote
Old 09-19-2019, 10:15 AM   #2
HarveyWallbanger
Default Re: LOTS of 1941-1948 Sedan Parts, New, NOS, Used, and Affordable!
Bttt.
Old 08-12-2020, 02:29 PM   #3
HarveyWallbanger
All sold.
Thread Tools
Display Modes
