Old 02-02-2019, 09:13 PM   #1
Steve Plucker
Steve Plucker's Avatar
Default The Rear Brake Camshaft Lever...
OK...I have to be crosseyed because I can not tell the difference between the Right and Left Camshaft Lever, A-2235 and A-2236.
I have a few and they all look the same to me...maybe they are I do not know.
The only markings on them is a "L" on some and "nothing" on the others.
I take it that the "L" stands for the LEFT lever and the ones that have no markings are for the RIGHT side.
Anybody?
Thanks.
Pluck
www.plucks329s.org
Walla Walla (WA) Sweet A's since 1993
MARC/MAFCA member since 1978
Ford Model AA Truck Club since 1998
(LIONEL/MTH Toy Train Collector, Orange Crush Soda Collector, Steel Beer Can Collector, Old Gas Pump Collector)
Old 02-02-2019, 09:52 PM   #2
TerryO
TerryO's Avatar
Default Re: The Rear Brake Camshaft Lever...
Steve, look very carefully at the end the brake rod goes on and you can see a very slight angle to correspond with the angle of the rod. I just went through this recently and I had to look at one on another chassis to see the angle. I hope this helps.
TerryO
TerryO is offline   Reply With Quote
Old 02-02-2019, 10:14 PM   #3
whirnot
whirnot's Avatar
Yeah, if you put them on backwards and try to hook up the rods, it becomes evident real quick.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 02-02-2019, 10:30 PM   #4
redmodelt
redmodelt's Avatar
The key way is different.
Old 02-02-2019, 11:03 PM   #5
Steve Plucker
There is no "key way" on these levers.
www.plucks329s.org
Old 02-03-2019, 01:20 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
stick a drill bit through the hole, the angle will be easier to see
Old 02-03-2019, 01:30 AM   #7
Dan Partain
Dan Partain's Avatar
Steve, these are from a 30-31 but I think the markings and angles would be the same if you lay them out on a table. See if these photos are any help.
-DAN
Dan Partain is offline   Reply With Quote
Old 02-04-2019, 12:48 PM   #8
larrys40
Yes there are left and right levers but are typically not marked. I previously misstated.
Emergency levers are typically marked. I’ve done a gazillion of these but sometimes you have a brain fart!
Larry Shepard
larrys40 is offline   Reply With Quote
Old 02-04-2019, 01:12 PM   #9
d.j. moordigian
d.j. moordigian's Avatar
Originally Posted by larrys40 View Post
Left and right service brake levers are the same, it just depends how they are oriented with relation to the brake cam when installed on respective sides .
Larry Shepard
I don't think so......!
d.j. moordigian is offline   Reply With Quote
Old 02-04-2019, 02:18 PM   #10
larrys40
D.j. You are correct. I know brakes in my sleep but had a brain fart for sure. Ever done that ?
Anyway, Thanks for your catch.
Larry
Old 02-04-2019, 02:36 PM   #11
d.j. moordigian
Larry
Ya,...I got up today.....lol
Dudley
Old 02-05-2019, 12:41 PM   #12
redmodelt
redmodelt's Avatar
I was thinking parking brake levers.
Old 02-05-2019, 03:02 PM   #13
Fullraceflathead
Fullraceflathead's Avatar
Just maybe all of yours are left?
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-05-2019, 07:30 PM   #14
JRrev
JRrev's Avatar
Vince Falter has done a study on this with his access to the Benson archives at the Henry Ford in Dearborn. Check out his Ford Garage at http://www.fordgarage.com/pages/rear...haftlevers.htm
Too bad he's not allowed on the fordbarn especially with his extensive knowledge of Model A's.
JRrev is offline   Reply With Quote
Thread Tools
Display Modes
