Old 09-06-2018, 12:27 PM   #1
Neil Wilson
Neil Wilson's Avatar
Default Hood Center Rod Diameter
Anyone know the diameter for the center rod for a hood? I am guessing it is 3/8" (.375"). But, the one rod I have seems to be slightly smaller.
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
Old 09-06-2018, 05:26 PM   #2
1955cj5
1955cj5's Avatar
Default Re: Hood Center Rod Diameter
I measured mine as you can see, it is slightly smaller on the ends near the sockets.
The section I measured is suppose to have part of the hinge around it but the hinge has been missing for a long time...
It also appears to be rolled like the original radiator supports. Does that seem right?
I've had the hood off but do not remember if it's a tube.....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 09-06-2018, 05:45 PM   #3
1955cj5
1955cj5's Avatar
Curiosity got the better of me so I took the hood support off and sure enough, mine at least, is a tube....
Smaller at this end also, no doubt due to wear...
Old 09-06-2018, 06:32 PM   #4
Terry, NJ
Terry, NJ's Avatar
3/8 O.D. tubing
Terry, NJ is offline   Reply With Quote
Old 09-06-2018, 06:54 PM   #5
Mike Peters
Mike Peters's Avatar
I recently used a piece of 3/8" threaded rod for a center hood hinge rod and it works OK. A non threaded 3/8" rod would be better. 5/16" ID brake line from auto parts stores is a bit loose.
Mike Peters is offline   Reply With Quote
Old 09-06-2018, 07:48 PM   #6
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Go to a welding shop and get one 3/8 in brass brazing rod, and two 1/4 in for the sides. They won’t rust and work good.
Jacksonlll is offline   Reply With Quote
Old 09-06-2018, 08:40 PM   #7
jw hash
jw hash's Avatar
the hood center rod is 3/8" the side panel rod are 1/4" I use stainless, it works good foe me
jw hash is offline   Reply With Quote
Old 09-06-2018, 11:56 PM   #8
Chris Haynes
Chris Haynes's Avatar
Just order new ones. Stainless won't rust out like what you have.
https://www.snydersantiqueauto.com/stainless-hood-rods
PS Clamp the end in a drill motor and rotate it to remove and replace the rods.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 09-07-2018, 11:56 AM   #9
Neil Wilson
I did some more research and found that the original top hinge rod is about 1/64th less than 3/8" diameter. And yes, this hinge was a seemed tube.
Vendors sell 3/8" diameter stainless steel solid rods. Snyder's sell "not solid" rods (but they don't look like the original seemed tube). It looks like 3/8" diameter rod is available industry wide.
Basically, getting the original .36+" diameter is not feasible today.
The Ford engineering drawing would likely provide the diameter they use.
Old 09-07-2018, 11:59 AM   #10
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
For pins, I use wood dowels, soaked in Linseed oil. NO RUST NO SQUEEK!
Bill Tricky
"THE ASSISTANT GURU OF STUFF"
Old 09-07-2018, 12:50 PM   #11
Chris Haynes
After nearly 90 years of use and abuse most hood hinges are worn and loose. The extra 1/64" fits just fine.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 09-08-2018, 09:17 AM   #12
SeaSlugs
SeaSlugs's Avatar
Ive been told the horn rod tube is same construction and diameter as the center pin... Take a measure neil. Theres tons of old horn rods layin around
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 09-08-2018, 09:49 AM   #13
daveymc29
daveymc29's Avatar
I had bad luck with the center tube and the drill motor. I did it quite slowly and carefully with a goodly dash of sewing machine oil to lube it up. About half way out it grabbed and looked like the remains of the old can lids that you took off with a key. (Remember the old tuna cans?) replaced with stainless from Bratton's.
daveymc29 is offline   Reply With Quote
Old 09-09-2018, 10:14 AM   #14
BILL WILLIAMSON
Or OLD COFFEE CANS! You WIND & WIND & the strip goes ASTRAY & you hunt for the PLIERS, to rip it off, while EVERYONES' waitin' fer COFFEE! WITHOUT COFFEE, there's NO MORNING LIFE!!!
In the mornings, ALL my body parts don't wake up at the SAME time, COFFEE even helps me get into LOW GEAR, I "thought" my clutch needed adjustment, but it was "OK"---LOL
Bill Slow
Thread Tools
Display Modes
