Old 11-20-2017, 06:39 PM   #1
melisahe
melisahe's Avatar
Default 8RT starter plate
Can anyone please tell me the difference between an 8ba and an 8rt starter plate. I bought one on evelbay, it was advertised as an 8ba F1F2 starter plate. After trying it ,I discovered that their is a strengthing ridge that is keeping it from going on all the way. Is that the way it should be?
Thanks Mike
melisahe is offline   Reply With Quote
Old 11-20-2017, 06:48 PM   #2
tubman
tubman's Avatar
Default Re: 8RT starter plate
Nope. Somebody sold you a bill of goods. An "8BA F1/F2" starter plate is a contradiction in terms.. Somewhere on the internet (it used to be on the old "Flathead Tips" site), there is a definitive write up (with pictures) on these. If you can't find it, I'm sure someone here has it at the tips of their fingers.
Old 11-20-2017, 07:04 PM   #3
Tim Ayers
I can take a picture of an 8RT set up if that helps.
Tim Ayers is online now   Reply With Quote
Old 11-20-2017, 07:26 PM   #4
melisahe
melisahe's Avatar
That would be very much appreciated and thank you.
Old 11-20-2017, 07:44 PM   #5
Mac VP
Mac VP's Avatar
This link shows the different bell housings and their matching starter plates....
http://www.vanpeltsales.com/FH_web/f...s-adapters.htm
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 11-20-2017, 08:03 PM   #6
melisahe
melisahe's Avatar
Mac VP. You nailed it for me. Thanks so much. It looks like I can cut the strenghting rib out and weld in a flat piece and it will work. Any thoughts on doing this as I havn't been able to locate the right part at this time.
Old 11-20-2017, 08:04 PM   #7
Ross F-1
Ross F-1's Avatar
Trucks had a "dust shield" at the back of the block, using the two oil pan bolts that straddle the crank oil seal. To accommodate that the starter plate was dished to the rear a small amount. See pics.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 11-20-2017, 08:40 PM   #8
melisahe
melisahe's Avatar
Thanks for the picture Ross F-1. Transbytip contacted me and has set me up with flywheel and 8rt starter plate. I want to thank everyone for all the help, I'd be lost without all your help. Mike
Old 11-20-2017, 09:15 PM   #9
Ronnie
Ronnie's Avatar
Here u go
Ronnie is online now   Reply With Quote
Old 11-20-2017, 09:55 PM   #10
Ross F-1
Ross F-1's Avatar
Originally Posted by Ronnie View Post
Here u go
I'm glad someone downloaded that, now that the Techno Source is DOA!
Old 11-20-2017, 10:11 PM   #11
flatjack9
flatjack9's Avatar
The 8BA plate has an angled starter mount and will not interchange with an 8RT plate as it is flat or parallel to the plate surface.
Old 11-21-2017, 02:24 AM   #12
Alaska Jim
Alaska Jim's Avatar
Actually the Techno site itself is still up at this time. just type flathead techno-site into your search eng. it will come up. I inquired several times before the other flathead site disappeared, if some one with good computer skills could put all that info on a flash drive ( I think that is what they are called ). I am sure that there would be plenty of people willing to purchase one at a reasonable price. I know I would. I would do it myself, but do not know enough to do it.
Alaska Jim is offline   Reply With Quote
Old 11-21-2017, 09:47 AM   #13
V8 Bob
V8 Bob's Avatar
I would really like to see pictures of the parts you have, if possible?
V8 Bob is offline   Reply With Quote
Old 11-21-2017, 10:03 AM   #14
melisahe
melisahe's Avatar
Bob, I'm an old fart, don't have a smart phone and don't want one. I do wish I had the knowledge to post pictures. I have a small camera, tried, but have given up. Maybe I can get my grandson to help me. It's hell getting old. Based on the pdf I have an 8ba starter plate and an 8rt engine bellhousing. I believe "transbytip" who is a member has the parts I need. Again Thank You everyone for your help. I will post when I receive the 8rt starter plate, 8ba flywheel and install it. Mike
Thread Tools
Display Modes
