Old 10-15-2017, 01:31 PM   #1
Floats
Floats's Avatar
Default Linseed oil on the patina??
Hi Guys,
I have a little surface corrosion starting on the leading edge of the doors.
In a previous thread Railcarmover mentioned "linseed oil on the patina"
Please tell me more.
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 10-15-2017, 03:14 PM   #2
1930-Pickup
Default Re: Linseed oil on the patina??
There's a lot of info about this subject on the web.
Here is just one site...you can distill this info for your application:
http://www.fullchisel.com/blog/?p=1157
1930-Pickup is offline   Reply With Quote
Old 10-15-2017, 03:54 PM   #3
Floats
Floats's Avatar
TKS,
Much appreciated.
Regards
Chris
Cape Town
Old 10-15-2017, 05:04 PM   #4
1crosscut
1crosscut's Avatar
If you go with the linseed oil I would urge you to use it mixed 50/50 with turpentine. Something to consider is what I have used on my trucks finish that is mostly surface rust is Johnson's Paste Wax. Works quite well and easy to work with.
A warning on the linseed oil. Be sure to lay your rags out flat to dry or they will spontaneously combust and possibly burn your house down.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-15-2017, 07:47 PM   #5
blgitn
blgitn's Avatar
Mineral spirits work for mixing with the boiled linseed oil too. Same caution about letting the rags dry flat on the ground outside. You can change the shine by changing the ratio a little; more thinner (spirits) equals more shine
blgitn is offline   Reply With Quote
