11-13-2010, 12:57 PM | #1 |
Lazy Ammeter
Since everything on my 29 coupe is highly suspect because of the previous owner, I was wondering about seemingly low indications on my ammeter. I've redone the gen. and I'm still getting an output on the guage of only 2 or 3 amps. Question: Can an ammeter actually get worn out? Are my readings correct? I don't want to keep advancing the 3rd brush until I fry something.
Thanks for any comments or thoughts Peter |
11-13-2010, 04:07 PM | #2 |
Re: Lazy Ammeter
Peter J - Your amp reading is too low, and ammeters can wear out. Two areas of wear are: 1) the needle movement (there may be something preventing the needle from full travel), and 2) the ammeter's magnet may be getting weak.
The ammeter is not hard to inspect. First, unhook the battery, next take all the screws out of the dash. , and then unhook and remove the ammeter. The outer bezel or ring is a compression fit and can be removed with gentle taps. Now you can inspect the needle movement for restrictions. As for testing the magnet's strength, that takes more equipment than the average A owner has. Do you belong to a Model A Club? If so, ask if a member has a known spare working ammeter, and try it on your car. Also, ammeters are not expensive, and you could order a new one from one of the vendors. Good luck solving the problem,
Ron/IA 1929 Fordor Steelback Hawk A Model A Ford Club http://hawkamodelaclub.org/ |
11-13-2010, 04:30 PM | #3 |
Re: Lazy Ammeter
Before you tear everything apart find an electronics friend with an ammeter (or buy one, cheap ones are about $10) and check the current by removing the wire going to the battery at the starter post and putting the ammeter into the circuit. Remember don't run the car without a complete circuit.
Charlie Stephens |
11-13-2010, 04:47 PM | #4 |
Re: Lazy Ammeter
be carefull of the new ones from the vendors they are junk
11-13-2010, 05:06 PM | #5 |
Re: Lazy Ammeter
A cheap ammeter will not work unless it is a anologue one . There is to much interference from the gen to make the digital ones work properly. just my 2 cents
11-13-2010, 05:07 PM | #6 |
Re: Lazy Ammeter
Most of the meters just need to have the cover removed, then use a toothpick and carefully put a drop of heavy oil on each of the two pivots for the needle. If you take the amp meter completely apart, make sure the magnet goes back the same way it came out. The heavy wire ring is the magnet, and if you suspend it by a thread one side will point north. Some people solder the studs to the buss bar for a foolproof connection inside the ammeter, but the main thing is to be sure the connections are clean and tight. I made a special wrench to tighten the nuts on the back of the original ammeter. ALL connections must be clean and tight. If you suspect a bad meter, connect a volt meter across the two terminal box wing nuts. If the terminal box nuts are tight and the 2 wires going to the ammeter are good, and the meter is good, then you should show less than .1 volts. To make this measurement you need current flowing, so turn the engine off and the lights on. Now, what does the voltage read across the 2 terminal box wing nuts? Also, what does the ammeter read? |
11-13-2010, 06:56 PM | #7 |
Re: Lazy Ammeter
Hey guys, that's great. I didn't know all that could go on with an ammeter. I was regestering good voltage from the gen. to the cutout and 8v from the batt. side of the cutout. Better not mess with the 3rd brush huh? Thanks for the pics. Tom.
Thanks Again !! Pete |
11-13-2010, 07:05 PM | #8 |
Re: Lazy Ammeter
Here's 3 more pictures with the first 2 showing an original guage, and the last showing a repro guage. Many repro guages are aluminum, and none of the repro's I've seen have the studs and top half of the bussbar painted flat black. When you look through the slot for the needle, anything you see should be flat black, and not shiney brass. |
11-14-2010, 01:31 AM | #9 |
Re: Lazy Ammeter
Sure doesn't look like their's much to go wrong with them. Shouldn't be a problem to check out the spring and solder connections. Great info and more keepers.
thanks Tom |
11-14-2010, 05:04 AM | #10 |
Re: Lazy Ammeter
Re only using analogue to check amps. I've experienced no problems checking amps with my digital ammeter/multimeter.
06-04-2013, 11:22 AM | #11 | |
Re: Lazy Ammeter
On the bench, can I use a VOM? What should the reading be? Thanks, Dudley |
06-04-2013, 01:04 PM | #12 |
Re: Lazy Ammeter
I've got my doubts that the ammeter is the problem. Ammeters can go bad from over charging but what i've seen, they either work or they don't. If adjusting the third brush doesn't change the charging rate, the brush wires are reversed. It will motor and charge even if the brush wires are reversed but adjusting the third brush will make no change in the rate of charge. look at the left lower corner of page 66 of the new Brattons catalog for the internal wire hook up legend for the tube type model A generator. If the wires are reversed, like I suspect, it will burn out the field coils if allowed to operate in this condition for an extended period.
06-04-2013, 01:13 PM | #13 |
Re: Lazy Ammeter
Purdy,
I have a bunch of ammeters(original)that I'm restoring and looking for a way to test them on the bench....too sort the good from the bad. |
06-04-2013, 02:59 PM | #14 |
Re: Lazy Ammeter
Dudley,
The voltage Tom is referring to is the voltage drop across the ammeter due to the resistance of the ammeter "shunt" while current is running through it. Ohms law....V=IR Hard to do on the bench unless you have a current going through the ammeter on the bench. Marc |
06-04-2013, 03:18 PM | #15 |
Re: Lazy Ammeter
Purdy, that is what I was thinkin too. Another good posibility to check. Great thread!
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
06-04-2013, 03:43 PM | #16 |
Re: Lazy Ammeter
You can put the 'snap' back in your ammeter by touching and stroking, from end to end, the old, tired magnet ring with a really powerful little nodym.. neodim.. rare earth magnet. Do it several dozen times. If you have an old computer hard drive to take apart you will find a good super-powerful neodymium magnet in there.
There are adjusting tabs or wings on the needle movement. Put it in series with a quality meter and about a 10 amp load. Best to adjust it mid-range. |
06-04-2013, 04:02 PM | #17 |
Re: Lazy Ammeter
I've seen a few generators that had the brush wires reversed by an electric motor shop nearby. When I saw them they would only charge 3 or 4 amps and brush adjustment did nothing. I like generator threads. I rebuild my own tube type generators. I don't know anything about the power house generators.
06-04-2013, 06:58 PM | #18 |
Re: Lazy Ammeter
Dudley, I do just as Mike K. said. I have a quality amp meter and put it in series with the Model A ammeter and put a 10 amp load in the circuit.
I also put a drop of heavy oil, like gear oil, on each of the 2 meter pivot points. |
06-04-2013, 07:09 PM | #19 |
Re: Lazy Ammeter
Tom,
Are you saying, use a 10 amp battery charger? Damn, I don't electricity well...if you catch my drift! Got a photo or a print?.....if I can see it...I can do it. Thank you! * Tom, if it's "yes" to the battery charger...I can do that.* Last edited by d.j. moordigian; 06-04-2013 at 07:25 PM. |
06-04-2013, 07:46 PM | #20 |
Re: Lazy Ammeter
You can use the battery charger as your power supply, but not as your load. Something like 2 headlamp bulbs would make a good load. They would be about 5 amps each for a total of 10 amps. You could even use a couple metal plates in salt water to make a load for the circuit.
Thread Tools | |
Display Modes | |
