Old 04-04-2015, 05:17 AM   #1
pre48V-8
pre48V-8's Avatar
Default '42-'48 Ford susp. & 47-'48 Ford sheet metal 4 sale used & orig.
City: Long Beach
State: CA
Price: $30 & up
Parting out a stock '47-8 Ford Super Dlx. 4dr. sedan . Orig. a Kern Cty. service vehicle, last owner took nice, complete car & cut off roof, chopped windshield, removed seats & dashboard assy. and removed eng./trans. by cutting through fwd. 'bell' & driveshaft w/torch directly behind trans. However, have a good, used '42-'48 Ford driveshaft & torque tube for the rear end assembly.
Chassis (frame & ft./rear susp. 4.11 gear ratio), sheet metal, bumpers, fuel tank, etc. in good shape (minor dents, no rust, surface pitting, rust holes, broken or bent mounting flanges/beads on fenders, running boards, gravel pans, etc.). Orig. black paint still visible on underside surface of all 4 fenders. Selling the parts & panels removed from vehicle (see images) individually or in pairs (where applicable) as listed below. Front susp. assy. & rear end/rear suspension assy. for sale (see details below).
  1. *Hood ornament ('47-8) $40
  2. *1 pr. hood hinges w/swing arms (1 spring missing-Drake $8; '42-8) $50
  3. *Lf. side rear fender inner brace panel ('41-8) $30
  4. *Rt. side rear fender inner brace panel ('41-48) $20
  5. *4 qty. 'smooth' s.s outside pass. car (no st. wagon) door handles ('47-8) $30 ea.
  6. *E-brake handle & cable w/clamps and hardware ('41-'48) $50
  7. *Ft. susp. assy. parts: tin covered ft. leaf spring w/orig. grease fittings, anti-sway bar, track bar (i.e., "Panhard bar"), steering tie rod & drag link, leaf spring & hardware (*No ft. drum brakes, spindles, wishbone, ft. axle or ft. shock mt.'s*) $150.00 for all or inquire for individual pieces.
  8. *1948 Ford stock, used, orig. rearend & rear susp. assy. parts: Rear factory tube shocks mounts, rearend w/4.11 gear ratio, complete rear drum brakes. Tin sheet metal covered orig. factory rear leaf spring pack, track bar, driveshaft and torque tube (no radius arms). $300.00
*NOTE*: List of parts available above will be periodically adjusted as parts sell prices subject to change w/o notice). Buyer is responsible for S&H costs, if applicable. Send private message w/any questions, comments or to request more detailed images of the pars. Thanks for your interest. PRE48V-8 \;^]
Last edited by pre48V-8; 12-17-2016 at 09:56 AM. Reason: price changes for parts listed & parts sold 12-17-2016
pre48V-8 is offline   Reply With Quote
Old 04-11-2015, 12:13 PM   #2
pre48V-8
pre48V-8's Avatar
Default Re: '42-'48 Ford susp. & 47-'48 Ford sheet metal 4 sale used & orig.
Bttt...4-11-2015.....*NOTE: rolling chassis availability date extended to 4-15-2015...begin disassembly (remove ft. & rear susp. assy.'s) 4-16-2015....
Old 04-19-2015, 11:30 AM   #3
pre48V-8
pre48V-8's Avatar
Bttt....4-19-2015.....have begun ft/rear susp. assy. removal & disassembly...will update images & parts desc./prices as components are separated.....
SOLD PARTS UPDATE (AS OF 4-11-0215)
rt. ft. fender; rt. ft. fender "filler" panel; lf. ft. vertical air deflector; ft. core support "wishbone-shaped" assy. (w/center spring bolt).....Have 1 party interested in fuel tank & 1 party interested in ft./rear factory shock mounts (they have 1st opportunity to purchase once these parts are listed)....Thanks! \:^] pre48v-8
Old 04-25-2015, 07:27 PM   #4
pre48V-8
pre48V-8's Avatar
Bttt...4-25-2015....ft. susp. available for sale as one unit for short time....rearend & rear susp. removal & disassembly has begun....have updated ad w/new images of individual items to show each in more detail & have adjusted the parts list to reflect items recently sold that are no longer available.....will cont. to update images & parts list to show items recently added and/or sold....
SOLD PARTS UPDATE (AS OF 4-25-2015)
3 pc. rear gravel panel assy.....Fuel tank available (prev. interesed party found another closer to home)....1 party interested in ft. susp. assy. (but no commitment; looking into S&H fees)....Ft. shock mts. go w/ft. susp. assy.; if ft. susp. assy. doesn't sell, will disassemble & offer ft. tube shock mounts as an individual item for sale....Thanks! \:^] pre48v-8
Old 05-02-2015, 11:55 AM   #5
pre48V-8
pre48V-8's Avatar
Bttt....5-2-2015....ft. susp. assy. still avail. for sale as a unit; will disassemble & list individual components for sale after rearend & rear susp. removed....will have rearend & rear susp. assy. out by mid-week, then list pictures & prices...will cont. to update images & parts list to show items recently added and/or sold.....
SOLD PARTS UPDATE (AS OF 5-2-2015)
1 pair ft. fender lower s.s. trim (sale pending); steering column assy. (sale pending); ft. susp. assy. still avail. (interested party never reponded back)...Thanks! \:^] pre48v-8
Old 05-09-2015, 03:04 PM   #6
pre48V-8
pre48V-8's Avatar
Bttt....5-9-2015.....**last opportunity to buy ft. susp. assy. as 1 unit** (see picture in ad above). Will disassemble ft. susp. assy. starting 5-11-2015 & post pictures & list descprition/price of each part indivudually. Rear susp/rearend has been removed & disassembled & is for sale individually (rearend w/4.11 ratio, O.E. rear tube shock mounts, rear radius arms, rear track bar, O.E. rear leaf spring pack (wrapped in factory tin cover w/O.E. grease fittings intact). Pictures of the rearend & rear radius arms are listed; will list rest of rear end susp. parts 4 sale ASAP. Send pvt. message for more info. (xtra pictures, questions)....
SOLD PARTS UPDATE (5-9-2015)
1 pair ft. fender lower s.s. trim=sold; complete steering column assy. (wheel to Pitmann arm & everything inbetween)=Sale pending....Thanks! \:^] pre48v-8
Old 05-17-2015, 11:12 AM   #7
pre48V-8
pre48V-8's Avatar
Bttt....individual ft. susp. parts available....will list each item w/price & some pictures next week in ad....the items from ft. susp. available are as follows: ft. spindles; tie rod & drag link; ft. track bar; sheet metal covered ft. spring pack w/u-bolts; ft. axle; ft. stock wishbone; 1 ft. drum brk. assy.; ft tube shock upper mount brackets......
SOLD PARTS UPDATE (5-17-2015)
gas filler neck=sold; driveshaft, coupler & fwd. support bearing=sold; steering column assy.=**Sale pending
Old 05-30-2015, 12:02 PM   #8
pre48V-8
pre48V-8's Avatar
Bttt.....no changes....5-30-2015.....refer to 5-17-2015 update notes....
Old 06-06-2015, 12:11 PM   #9
pre48V-8
pre48V-8's Avatar
BttT...no changes...6-5-2015...refer to 5-17-2015 update notes...ft. end still intact as a unit due to delay of its disassembly...will disassemble next week & update next weekend...
*SELLING @ LA ROADSTERS SWAP MEET IN POMONA,CA June 19-21,2015
*WILL HAVE THESE PARTS & OTHER 1941-48 FORD INTERIOR/TRIM PARTS 4 SALE
*LOOK FOR COLEMAN TENT TRAILER & WHITE CHEVY C1500 2WD P/U & TAN "POP-UP"
Old 06-13-2015, 02:54 AM   #10
pre48V-8
pre48V-8's Avatar
Bttt...no changes....6-13-2015....refer to 5-17-2015 update notes....ft. end still intact as unit due to cont. delay of it's disassembly due to family commitments....will try to get it apart early next week before LA Roadsters swap meet...ft. end still avail. as shown in picture for $400.00....look for updates next week (or week after Father's Day)...
*SELLING @ LA ROADSTERS SWAP MEET IN POMONA, VA June 19-21,2015...
*WILL HAVE THESE PARTS & OTHER 1941-48 FORD INT./TRIM PARTS 4 SALE....
*LOOK FOR COLEMAN TENT TRAILER & WHITE, '97 CHEVY C1500 2WD P/U & TAN "EZ-UP" CANOPY....
Old 06-19-2015, 01:01 AM   #11
pre48V-8
pre48V-8's Avatar
Bttt...no changes.....6-18-2015
*SELLING @ LA ROADSTERS 51ST SWAP MEET @ FAIRPLEX, POMONA CA
*SEE THESE PARTS AND OTHERS @ SWAP MEET JUNE 19, 20 & 21, 2015 (FRI.-SUN.)
*LOOK FOR COLEMAN TENT TRAILER & WHT. '97 CHEVY CK1500 P/U
Old 06-27-2015, 12:11 AM   #12
pre48V-8
pre48V-8's Avatar
Bttt.....6-26-2015....no changes....prices & parts still same....will be adding some more parts in a week (ft. & rear susp.).....
Old 07-04-2015, 10:51 AM   #13
pre48V-8
pre48V-8's Avatar
Bttt...7-4-2015....no changes....prices & parts still same....family summer plans delaying adding addl. parts to list (check mid-July for updates)......Happy Independence Day!
Old 07-12-2015, 11:09 AM   #14
pre48V-8
pre48V-8's Avatar
Bttt...no changes......7-12-2015
Old 07-18-2015, 11:26 AM   #15
pre48V-8
pre48V-8's Avatar
Bttt.....no changes.....7-18-2015.....SELLING @ LONG BEACH FORD MODEL T SWAP MEET @ LOS ALAMITOS HORSE RACE TRACK PARKING LOT, KATELLA AVE., LOS ALAMITOS, CA SAT. JULY 25, 2015 7AM-???
Old 07-26-2015, 08:00 AM   #16
pre48V-8
pre48V-8's Avatar
Bttt....note changes to parts & price list.....7-26-2015
hood sold @ L.B. Model T meet; frame is $500; rear end/rear susp. assy. (no torque tube or driveshaft) is $350.00....
Old 08-02-2015, 11:50 AM   #17
pre48V-8
pre48V-8's Avatar
Bttt....note changes to parts list.....8-2-2015
Old 08-08-2015, 03:23 PM   #18
pre48V-8
pre48V-8's Avatar
Bttt....no changes....8-8-2015
Old 08-14-2015, 04:25 PM   #19
pre48V-8
pre48V-8's Avatar
Bttt...no changes....8-14-2015
Old 08-28-2015, 11:56 PM   #20
pre48V-8
pre48V-8's Avatar
Bttt....no changes....8-28-2015
Thread Tools
Display Modes
