02-20-2015, 11:48 AM | #1 |
iInner axle bearing race or cup
IS THERE A SPECIAL PULLER OR IS THERE ANOTHER METHOD FOR REMOVING THESE MINE ARIECVE PITTED BAD.39 PKUP. THANKS FOR ANY ADVICE sunshine
02-20-2015, 12:51 PM | #2 |
Re: iInner axle bearing race or cup
I usually press them out. Made a rectangular steel bar that goes into the axle housing, through that bearing race ID, and sits on the very edge of what is exposed of the bearing race. Then I insert an old axle, threaded end first, in through the small end of the axle housing until the axle comes against the steel bar. Then pressing from the gear end of axle in my Arbor Press, I press the bearing race out of the axle housing.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 02-21-2015 at 05:32 PM. |
02-20-2015, 01:02 PM | #3 |
What I do is using a mig welder run a HOT weld bead on the face of the race. This shrinks the race to where they almost fall out. If not a small diameter rod will easily punch them out.
02-21-2015, 04:35 PM | #4 |
just did mine used long prybar down the tube into the center of the race then lifted it to feel the edge of the race, tapped a few times on each side and it fell out took less then a minute.
02-21-2015, 05:48 PM | #5 |
Huh? He says 39 pickup. Inner axle bearing. Something doesn't add up here. What's the discussion about axle housings and long tools? The inner axle bearing is where???
Are we talking about front, or rear axle? OK, got it... CARRIER bearings... now it makes sense Last edited by bobH; 02-22-2015 at 12:13 AM. |
02-21-2015, 10:26 PM | #6 |
Mark |
02-21-2015, 11:54 PM | #7 | |
02-22-2015, 06:48 PM | #8 |
I made this versatile tool, helps with a number of jobs.
02-22-2015, 08:13 PM | #9 |
Interesting...I have similar tool my Dad and I used for years...will post a pic ...but what we used/I use was a tool that was made to pack hot lead in water pipes as my Dad told me...pretty much the same as you have...just struck me funny!
02-22-2015, 09:07 PM | #10 |
Born from necessity ! look forward to the pics..
02-22-2015, 10:19 PM | #11 |
Will get them tomorrow, knocked in so many bearing races, I couldn't count, never used it for getting them out, was always able to use a long drift punch for that...
But, I tell you, tomorrow you'll be so suprised at what you made resembles what I have...lol! |
02-23-2015, 08:21 AM | #12 |
THANKS FOR ALL OF THE SUGGESTIONS , I guess I should have called it the differenial inner bearing race or cup I guess I will make something to try and drive them out . NO PRESS OR WELDER THANKS sunshine
