Old 01-28-2015, 02:19 AM   #1
clay co 27
Default late 1931 cast iron brake drums
Are they better than the earlier steel, and did Ford carry them over to 1932?
thanks
clay co 27 is offline   Reply With Quote
Old 01-28-2015, 02:33 AM   #2
jw hash
jw hash's Avatar
Default Re: late 1931 cast iron brake drums
yes they are better than the earlier press steel drums . Ford did carry over the design but made them bigger. 1932 came out with 12" drums instead of 11" that the Model A used.
jw hash is offline   Reply With Quote
Old 01-28-2015, 10:34 AM   #3
larrys40
In my opinion they are the front drum of choice since the hub and drum are one piece, the front hub does not typically have the race issues the pressed steel ones have . As long as they are not pitted up and not way oversize they are my number one choice even over the new cast iron for the hub reason. They are out there but hard to find. The fronts are much more plentiful than the rears. In fact plan on probably never finding the rears ... But the fronts are obtainable here and there with a good eye over time.
The next best are the New cast irons from Mel/randy gross/ Snyders/ Brattons, or other cast iron of your choice in my opinion.
Larry Shepard
Last edited by larrys40; 01-28-2015 at 06:23 PM. Reason: New Cast Iron drum sources/suppliers
larrys40 is offline   Reply With Quote
Old 01-28-2015, 11:48 AM   #4
mrraford
My '31 Pickup wears a set of "Rocky Mountains" that surfaced after much searching at swap meets. The pickup brakes work much better than the stamped steel drums I've endured before. No worries whether the vehicle will stop or not.
After spending the money to buy a set of the modern cast irons for my 68C, I found another set of the original cast irons. I have them on the shelf at home.
mrraford is offline   Reply With Quote
Thread Tools
Display Modes
