Old 11-03-2014, 09:30 PM   #1
bmodeltman
Default 2 piece front pulley
I have a new 2 piece pulley that has the 2 tabs that line up.The seal sleeve part of it has square cut tangs on it and the pulley part is cut so it has rounded corners and doesn`t fit tight against the sleeve.There`s about an 1/8 inch gap between pulley and sleeve.Is this suppose to be this way to press them together or do I have to file the pulley tangs to fit the sleeve?
bmodeltman is offline   Reply With Quote
Old 11-04-2014, 03:45 AM   #2
H. L. Chauvin
Default Re: 2 piece front pulley
If you would like to hear one serious opinion & sound advice offered from years of engine rebuilding & balancing experience, please call engine re-builder Mr. Ron Kelley, (advertised in The Restorer magazine), & ask his opinion on pros & cons of installing today's offered Model A (1) piece pulleys and/or the (2) piece pulleys.
H. L. Chauvin is offline   Reply With Quote
Old 11-04-2014, 05:32 AM   #3
tbirdtbird
it doesn't sound properly made. The male and female tangs are supposed to engage fully and both should be square cut. Return to vendor for proper one
'31 180A
tbirdtbird is offline   Reply With Quote
Old 11-04-2014, 11:54 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
I agree with Tbird . Also a picture would help us understand better what you are reffering to.
Old 11-04-2014, 03:47 PM   #5
Russ/40
Russ/40's Avatar
I suspect the grooves are longer than the tabs. Thus assures the outer pully will be seated fully. The rounded area in the grooves are to prevent a stress point that may lead to a fracture. I think your fine. A photo will confirm my observations.
Russ/40 is offline   Reply With Quote
Old 11-04-2014, 11:03 PM   #6
bmodeltman
Thanks for the info guys.The two piece pulley that was on my engine was cracked.When I bought this project it came with a lot of boxes of parts and found a new pulley and thought it was the same.But it isn`t.I did find find an orginal one piece in the mess.I`ll clean it up and hopefully it`s ok and use it.
