Old 01-02-2014, 08:55 PM   #1
Admiral
Admiral's Avatar
Default Restored Air Cleaner
I just finished restoring the air cleaner for my ’36 Fordor. I think it turned out pretty well; it’s amazing what a wire wheel and a little paint will do. But that’s not all…
I modified the housing to accept a modern, washable conical filter. With a few small changes (and quite a bit of work) it fits beautifully in the assembly. The whole thing had to be gutted, which was quite a process.
Now, before you all get your britches in a bind I’m not one that normally destroys scarce antique items that are perfectly good. But the problem is a previous owner of my car thought it was a good idea to BEAD BLAST the air filter housing. As you guys know these items aren’t really serviceable. No amount of blowing with the air hose or washing in the parts tank could get all of that abrasive crap out of the housing, which is why I made the tough decision to tear it apart and make these modifications.
On the bright side it should filter much better than the stock assembly and probably flow a lot more in the process.
Admiral is offline   Reply With Quote
Old 01-02-2014, 10:23 PM   #2
moonshine runner
moonshine runner's Avatar
Default Re: Restored Air Cleaner
Looking good!!
Kevin
moonshine runner is offline   Reply With Quote
Old 01-04-2014, 05:38 PM   #3
al's28/33
al's28/33's Avatar
Good thinking! and it looks great!
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 01-04-2014, 05:44 PM   #4
koates
Hi there, Very good job. Could you please post the brand name and part number of that washable filter. THANKS. Regards, Kevin.
koates is offline   Reply With Quote
Old 01-05-2014, 12:00 AM   #5
Lawson Cox
Lawson Cox's Avatar
Restored??? Wouldn't the proper term be re-designed???
Your wife is going to climb your frame if you mess up that nice breakfast table. LOL
Old 01-05-2014, 03:27 AM   #6
Graeme / New Zealand
Graeme / New Zealand's Avatar
Looks good and I like your beer stein too.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 01-05-2014, 06:48 AM   #7
dwick01
dwick01's Avatar
Quality one. Excellent work!
dwick01 is offline   Reply With Quote
Old 01-05-2014, 07:15 AM   #8
Charlie ny
Admiral,
How did you separate the top and bottom ?
Charlie ny
Charlie ny is offline   Reply With Quote
Old 01-06-2014, 09:08 AM   #9
Admiral
Admiral's Avatar
Koates, the brand is Spectre. I bought it at Advance Auto Parts. It's a generic version of K&N and only cost about $20, which is less than half the price. I do not know the part number... I mistakenly threw the box away! I'll get you some measurements later today.
Yeah, perhaps. No need to worry, there's no wife to quarrle with and that's not a breakfast table; it's actually a stand-up desk I made a few years ago out of scrap hardwood flooring.
Originally Posted by Charlie ny View Post
Admiral,
Charlie ny
Charlie, I separated the canister just below top flange. I chucked it up in the lathe, ran it in back gear (SUPER slow) and ground it apart with a cut-off wheel. With how thin the metal is and how off-center it tends to clamp in the chuck you CANNOT use a regular cutter.
Old 01-06-2014, 01:38 PM   #10
Admiral
Admiral's Avatar
Koates,
The smaller end of the filter measures just about 4.75 inches in diameter; the larger one clocks in at 6 inches. The whole assembly measures about 6.25 inches high BUT you have to cut the rubber adapter off the filter so it fits in the assembly (see picture below). I used a utility knife to do this and simply cut it off at the base of the filter element. With a sharp blade it cuts like butter. With the adapter portion removed it measures about 4.625 (4 5/8) inches high.
Old 01-06-2014, 02:39 PM   #11
JM 35 Sedan
JM 35 Sedan's Avatar
I may try to separate a beatup one like that I have with surface rust pitting, but I would probably try making the cut at the bottom of the crimped flange so there would still be a flange on the top and bottom halves. I think this might keep the mating areas on both halves a bit stronger. I am also thinking maybe it could be made into an oil bath and keep the original dry filter element and screen at the to to look original. Just some thoughts. This may wind up being a better method of separation than the previous method of cutting those three legs at the top and soldering them back together after new elements are installed. Just some random thoughts but it took your pictures to get me thinking
John
Old 11-22-2014, 08:35 PM   #12
johndee138
johndee138's Avatar
The Spectre filter # is 9132 and it was $20 at the above mentioned store. This modification isn't a quick little project. Some fab work, and a LOT of zip wheel, nibbler, metal snips, files, rotary grinders of various types to get all the metal out of the inside to make it all work out. All that being said it will be worth it to me. I cant imagine that the stock "air filter" really did much of anything save keeping the leaves out of the carb throat!
johndee138 is offline   Reply With Quote
Old 02-22-2015, 03:48 PM   #13
keith oh
keith oh's Avatar
I don't think any of us run our cars around on dusty dirt roads, at least I don't so I followed Fords instructions, " Wash with gasolene(I use laundry soap) rinse and dry, coat with engine oil and replace". I have run the old 35 since 1959, still runs good and uses no oil so must be an safe method.
keith oh is offline   Reply With Quote
Old 02-22-2015, 05:53 PM   #14
Jakno
Jakno's Avatar
Keith, what part are you referring to when you say Ford's instructions are to rinse with gas, etc ?. is it the wire mesh behind the square screen filter ?. thanks
Lineman, the only dumb animal that can harness himself !!
Jakno is offline   Reply With Quote
Old 02-22-2015, 07:12 PM   #15
TonyM
TonyM's Avatar
Yes, the metal mesh should be oiled per Ford.
Here is the decal that the manufacturer attached to the side of the 1937 Ford Air Cleaner. Left is a 1939 aircleaner (91A-9600) and on the right is a 1937 part (78-9600)
File Type: jpg 1937-1939%20Ford%20Air%20Cleaner%20Decal.jpg (22.8 KB, 62 views)
TonyM is offline   Reply With Quote
Old 01-22-2018, 08:41 PM   #16
Admiral
Admiral's Avatar
It's been brought to my attention that the images on this thread have not been showing up. Some people wanted to see how I completely reworked the air cleaner on my '36. In case the original photos, which are hosted on that dreadful website Photobucket.com, aren't displaying properly, I've attached resized copies here. Hope this helps!
Old 01-23-2018, 12:06 AM   #17
Kahuna
Kahuna's Avatar
Thanks Craig for the reposting.
Regards
Jim
Kahuna is offline   Reply With Quote
Old 01-23-2018, 07:18 AM   #18
lotsagas4u
Very nice work, did these air cleaners always have the top pad? I have seen some with and some without. Can you buy replacements?
lotsagas4u is offline   Reply With Quote
Old 01-23-2018, 10:41 AM   #19
carguybill
carguybill's Avatar
Why am I unable to see the photos in the earler postings? Seems like some problem with Photobucket.
carguybill is offline   Reply With Quote
Old 01-23-2018, 11:31 AM   #20
JSeery
JSeery's Avatar
Those links are no longer allowed, except with a high fee which most will not pay.
