Old 06-13-2013, 09:17 PM   #1
Johnnyj
Default Dry rod bearings
Recently ran a flathead v8 that I was told had been overhauled but never ran in over 20 years. On first run the engine overheated with smoke coming out the breather. Disassembled engine, removed the plugs from front and rear of oil passage and founds blockage in that line.......The rod bearing were dry. Cleaned out, put in new rod bearings and seems like the same problem......no oil getting to rod bearings. The engine is a 1941. The block is going to be vatted and cleaned prior to next build. Any ideas on why oil is not getting to the rod bearings??
Johnnyj is offline   Reply With Quote
Old 06-13-2013, 09:34 PM   #2
flatjack9
flatjack9's Avatar
Default Re: Dry rod bearings
Do you have a pressure gauge and does it register pressure when running?
Old 06-13-2013, 09:42 PM   #3
Brian
Brian's Avatar
Has it been modified for full flow filtration?; this involves putting a plug in oil gallery at rear of engine. If so modified, you'll need to either remove said plug, or plumb in the exterior lines etc to suit.
Brian is offline   Reply With Quote
Old 06-14-2013, 08:53 PM   #4
Johnnyj
There is a plug in the front and rear of the oil tube that runs front to rear of the block
Old 06-14-2013, 08:56 PM   #5
Johnnyj
Yes, 40 lbs pressure
Old 06-14-2013, 09:07 PM   #6
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
If the plug was installed in the horsontal line to the main oil line you would still have oil pressure from the pump but it wouldn't go across to the main line. You have 2 plugs back of the block where to pressure sender unit goes. remove the side one and see if you can stick a screw driver in there about 6in. If it only goes in an inch or so there is a plug in there. I had one of those blocks last year that had the same problem. On mine some one had tried to remove the fuel pump push rod bushing and broke It off and it was blocking the main oil line. Hard thing to find. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 06-14-2013, 11:18 PM   #7
Bluebell
The plug Walt is talking about, would have been fitted, if the engine had a cooler, or a filter fitted. It would likely have another plugged hole above the oil gallery casting boss (which already has a side and top tapping)
Going to Walt's You tube clips on the v8 oiling system might help you.
Bluebell is offline   Reply With Quote
Old 06-15-2013, 04:28 PM   #8
Zeke...PA
Zeke...PA's Avatar
Here is a diagram showing the plug in question if modified for full flow. The grub screw would be the problem if not plumbed. Zeke
Only problem with retirement is never a day off
Zeke...PA is offline   Reply With Quote
Old 06-16-2013, 08:47 AM   #9
Johnnyj
Thanks for the info, I'll check the plug out when I see the block later this week
Old 06-16-2013, 09:13 AM   #10
296 V8
Did you check that the cam shaft bearings are clocked correctly?
296 V8 is offline   Reply With Quote
Old 06-16-2013, 10:06 AM   #11
JWL
Good question from 296 about cam bearings being indexed correctly. Also, is the front bypass spring and valve in place? Is the fuel pump rod bushing installed??
JWL is offline   Reply With Quote
Old 06-16-2013, 11:29 PM   #12
Johnnyj
The engine ran for a short time and sounded good to me. The bypass spring and valve were in place. When I get the block back ,I'll check the plugs mentioned and hopefully find the problem. The fuel pump bushing was damaged. It was removed and will be replaced when block returns
Old 06-17-2013, 06:18 AM   #13
Mart
Mart's Avatar
If it did have the oil passage plug fitted, the front two main bearings will also have been run dry. (Only the rear main will have received oil). It would be good to give them a good look at too.
Mart.
Old 06-17-2013, 07:09 PM   #14
Johnnyj
Many thanks for the info., it all helps. I'll let all know what we find.
Thread Tools
Display Modes
