02-19-2020, 10:08 AM | #1 |
Need a piston
Working on a 38 21 stud engine .060 over 4 ring dome pistons,one has a burned spot in ring gland,,,, have searched the adds and no one has one but did find a set of ring but no piston so thought I would ask here if someone has one stacked away
Pm me if you have one,,,Thanks One other question,oil pump did not have gasket on the plate over gears,have seen them with and without,do I put one on??? I think I’ve always put them on,,
DON P |
02-19-2020, 10:37 AM | #2 |
Re: Need a piston
Was a common fix to tighten the axial play on the pumps.
Measure what you have adding a gasket may lower the performance of the pump. |
02-19-2020, 05:11 PM | #3 | |
Re: Need a piston
02-19-2020, 06:01 PM | #4 |
Re: Need a piston
What brand--- I won't be able to look till the weekend--- if there's a single or less than a set it will be Ford, possibly choice of weight too
02-19-2020, 08:57 PM | #5 |
Re: Need a piston
They were all ford pistons 4 ring,,,, domed. Thanks
DON P |
02-21-2020, 06:48 PM | #6 |
Re: Need a piston
02-22-2020, 10:49 AM | #7 |
Re: Need a piston
Bummer,anyone else or have ideas!!!!
DON P |
02-22-2020, 12:30 PM | #8 |
Re: Need a piston
I have a piston of the 3 ring design, about a hundred gram difference in weight vs the 4 ring.
02-22-2020, 09:37 PM | #9 |
Re: Need a piston
Will send you a PM about that piston you need. I have several.
02-23-2020, 12:06 AM | #10 |
Re: Need a piston
I don't have any, set of 040,few std, lots of steel pistons--- hadn't looked in that box for a lon time
02-23-2020, 12:21 AM | #11 |
Re: Need a piston
You should be able to find one on ebay. I have done so many times.
02-23-2020, 07:56 AM | #12 |
Re: Need a piston
You may also check with Fred Wilner at SSO, or Ray Helgers in RI 401 635 4849
