04-02-2022, 07:33 PM | #1 |
Shoebox wiring question
I have a new wiring harness for the dash forward on hand for my'51 Tudor. Does the rear body/taillight harness go forward above the headliner or along the floor and door sill plate? Thanks for any info.
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
04-02-2022, 08:49 PM | #2 |
Re: Shoebox wiring question
Drivers side inside the channel created by the roof framing, I would not go there unless you plan on replacing the headliner, which normally requires removing the back window. Because Ford did it does not make it a good idea. Mice love to nest in that channel.
04-03-2022, 08:50 AM | #3 |
My convertible goes under the sill plate. Then it goes to the rear quarter and into the trunk.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
04-03-2022, 08:54 AM | #4 | |
Don, thanks for the response. I had a hunch this would be the case, and the headliner and windlace will get replaced,..... just not now. I will just have to mend some of the wiring near the taillights for now.
04-03-2022, 02:31 PM | #5 | |
Hmmm, so I could route the harness using the convertible path. I see the rear harness for convertible is about $75.00 more than the other body styles. I imagine there is more wire for the top pump and switch?
04-04-2022, 07:28 AM | #6 |
04-04-2022, 07:56 AM | #7 |
My 1949 Fordor runs along the floor and drivers sill. The only wiring going toward the headliner is for the courtesy lights.
Check any wiring diagram in any of Fords Chassis Parts and Accessories Catalogue -- wiring to the rear -- goes on the drivers side floor. |
04-04-2022, 09:55 AM | #8 |
Yes!
Sent from my SM-G960U using Tapatalk |
04-04-2022, 09:58 AM | #9 |
Sorry, I meant yes it goes up the A pillar along the roof and down above the rer side window then down to the trunk.
Rob Sent from my SM-G960U using Tapatalk |
04-04-2022, 05:17 PM | #10 |
I checked the diagrams, for 51 it shows wires above over the doors and below at the rockers. My 50 did not have factory signals and the wiring is in the roof. I think you get to take your pick, not a tough one to figure out.
04-04-2022, 05:45 PM | #11 | |
Don, with the previous responses, and with seats and everything coming out for carpet, I'm going to run wires through quarter, along floor and under sill plates. I'll remove old wiring above headliner (if that's where it is) when replacing headliner next year. Everybody's responses most appreciated!
