05-15-2013, 04:24 PM | #21 |
Re: Inherented '28 A model Ford I don't know if it's a Curse or a gift
That is truly a gift. He obviously thought you'd appreciate it and take care of it the way he would. Put 21's" on it and enjoy it. Sell the 19's the way they are, the new owner may want to keep the old tubes, if the troubles I’ve read about the new ones are true. I don't think 16" look right on a 28-29 but would be better than any solid wheel. If there aren’t any problems with the wire wheel they are plenty strong enough. One last thing, whatever wheel you decide on, bolt one at a time up before you purchase and spin them to make sure they are straight.
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
05-15-2013, 10:10 PM | #22 |
If you have 19" wheels cracked around the lug nut holes and you have a 28 (what date on firewall?) you may need AR 21" wheels. The early 28 AR hubs use a wheel with a shallower hub chamfer. Using a later wheel on AR hubs will cause the cracks around the lug nut holes because the later wheels will not contact the early hubs.
05-15-2013, 10:27 PM | #23 |
From the looks of your upper radiator hose I think you have a 30-31
water outlet neck, the 28-29 one is shorter. Bob Last edited by Bob C; 05-15-2013 at 10:38 PM. |
