05-14-2013, 08:54 PM | #1 |
Engines misses at higher rpm
What is first thing to look for if my A misses at higher rpm?It idles fine.
05-14-2013, 09:39 PM | #2 |
Re: Engines misses at higher rpm
Generally speaking it will be spark related but it could be one of several things. The first thing I would check would be points gap and make sure they are dressed properly. Coil polarity that is reversed will cause hi-speed issues too. If it is fuel related, maybe the GAV is too lean? Amazing what hearing does for diagnosis!!
05-15-2013, 10:58 AM | #3 |
I'll go along with Brent's suggestion on the first and easiest thing.
Changing plugs won't solve incorrect gap or pitted points.
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
05-15-2013, 01:00 PM | #4 |
