Old 05-14-2013, 07:27 PM   #1
sphooch
sphooch's Avatar
Default Need a valve job
Hay Guys a couple of questions for the Barn Wizards ; I'm new to the model A so I have many questions.I'm now starting to work on the stuck valves. I still have 1 stuck lifter, and 2 stuck valves . any idea on how to free the stuck valves. I'm using MMO and propane heat, no luck on these couple. If I remove the head, how do I free up the valve?? If I remove the head, may as well do a valve job, I have alot of LES ANDREWS books and Ford restorer but first hand info is always helpful. If I buy new valves and compont parts how do I measure the spring pressure?? I saw in a search to use a bathroom scale and a drill press , both of wich I have.How do I remove the guides , do I need special tools?? what kind of valve grinder is used??and of course how are they adjusted? There are no clubs that I know of here in N J , so any one taking the time to advise me , its greatly appreciated . thanks THE HOOCH
sphooch is offline   Reply With Quote
Old 05-14-2013, 07:35 PM   #2
charles=fla
Default Re: Need a valve job
Mr HOOCH if ya come to lakeland on the 25 ill give you a engine,tools,and a beer and you can do a valve job for me..kinda on the job trainning..and i will have 2 other supervisers to show ya how not to pop out the valve guides.brass hammer required..el wappo..)..
charles=fla is offline   Reply With Quote
Old 05-14-2013, 09:02 PM   #3
Bob C
Where are you located?? I found five clubs, two MAFCA and three MARK in NJ.
Bob
Old 05-14-2013, 09:11 PM   #4
lookin-backtexas
lookin-backtexas's Avatar
I had a couple of stuck valves many years ago from having let my Model A sit undisturbed far too long and a friend in my local Model A Club told me to squirt some automatic transmission fluid through the spark plug holes toward the stuck valves and let it sit for a couple of days; claimed it would free them right up. Sure enough a couple of days later I started the Model A and the garage filled up with so much smoke that I couldn't see squat! In a couple of minutes I looked through the "fog" and there were several sets of red emergency lights flashing in my driveway! A neighbor had seen all the smoke and called the fire department. The firemen got a good laugh out of it and brought in some of their fans and cleared the place out. Then hung around long enough after the smoke cleared so they could look the car over thoroughly.
Fred Carlton
Life Member AACA
44 year member MAFCA
Editor of The Restorer magazine, official publication of MAFCA 12 years
Life Member Dallas Model A Ford Club (44 years)
23 year member & founder Lone Star Model A Ford Club
Chairman 35th Model A Ford Texas Tour 1998 (state convention)
Chairman 42nd Model A Ford Texas Tour 2005 (state convention)
Charter Member Ford Model AA Truck Club
If you aren't driving your antique car frequently, you might as well be collecting clocks!!!
lookin-backtexas is offline   Reply With Quote
Old 05-15-2013, 07:48 AM   #5
sphooch
sphooch's Avatar
Hi , Bob I'm located in central N J in a little town named Laurence Harbor. [ south amboy] I've contacted MAFCA for info. reguarding clubs in my area but they never responded. If you can share your finding with me I would appreciate it . thank you THE HOOCH
Old 05-15-2013, 07:52 AM   #6
sphooch
sphooch's Avatar
Hey cousin , Plans are for me to be there . it would be great for some hands on info. So now before I do anything at all I'm gonna wait till I see you guys and don't mess anything up. thanks reguards to Hellen . THE HOOCH
Old 05-15-2013, 04:17 PM   #7
ctlikon0712
ctlikon0712's Avatar
Here are the links for MARC and MAFCA's local chapters.
http://www.mafca.com/chapters_list.html
http://modelarestorers.org/newsmanag...%204-20-13.pdf
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 05-15-2013, 06:03 PM   #8
1931 flamingo
1931 flamingo's Avatar
Mix ATF and acetone 50/50 and then apply, no heat. FWIW
Paul in CT
Old 05-15-2013, 07:01 PM   #9
Bob C
Here are the links to the list of clubs.
http://www.mafca.com/chapters/NJ.html
