Old 02-14-2019, 04:13 PM   #1
Smooth_One
Smooth_One's Avatar
Default Vintage Precision thermostat housing
I just got my thermostat housing from Casey at Vintage Precision.
I’ll take some pictures when I get it installed and give a review after running it for a few weeks.
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 02-14-2019, 04:29 PM   #2
Herb Concord Ca
Default Re: Vintage Precision thermostat housing
You will love it! I have this housing on both of my A's. Check the 2 plugs for a temperature gauge, to make sure they have thread sealant on them. Casey is the son of the designer. You'll be surprised how fast the motor comes up to temperature.
Herb Concord Ca is offline   Reply With Quote
Old 02-14-2019, 05:19 PM   #3
Smooth_One
Smooth_One's Avatar
Oh good! I’m sure it will work great. My car does take forever, even here in Florida.
Isaiah B.
Old 02-14-2019, 05:20 PM   #4
copgib
copgib's Avatar
I have the same item. Works great and I am sure you will love it! Hugh
copgib is offline   Reply With Quote
Old 02-15-2019, 01:51 AM   #5
verdirick
Smile Re: Vintage Precision thermostat housing
guys, I have been running one on all 4 of my A's for years. Quality after market unit... Henry probably would have used one had they been available..
verdirick is offline   Reply With Quote
Old 02-15-2019, 09:05 AM   #6
ryanheacox
ryanheacox's Avatar
Always liked the look of those, seems like a high quality item. Will you be plumbing in a bypass hose?
Old 02-15-2019, 12:58 PM   #7
CarlG
CarlG's Avatar
I have been running one of these for quite a few years. I have a temp gauge on the small port, and use the larger one to feed my heater.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-15-2019, 01:32 PM   #8
Benson
Benson's Avatar
One thing to remember when replacing the Thermostat is that V P uses the Stant manufactured "SuperStat".
The "SuperStat" is a different animal from the standard Stant Thermostat and other brands and is the reason for the way this product works in the Model A!
Last edited by Benson; 02-15-2019 at 03:42 PM. Reason: corrected spelling of SuperStat all one word ...
Old 02-15-2019, 02:39 PM   #9
CarlG
CarlG's Avatar
Originally Posted by Benson View Post
One thing to remember when replacing the Thermostat is that V P uses the Stant manufactured "Super Stat".
The "Super Stat" is a different animal from the standard Stant Thermostat and other brands and is the reason for the way this product works in the Model A!
Sooooo, What is different about it? I have successfully used other thermostats there and have had no problems.
Alaskan A's
Old 02-15-2019, 03:09 PM   #10
Ruth
The Stant Superstat is designed to reduce cycling. I personally have not used one so can not attest to that.
I use a regular thermostat in the top hose and it works fine. Once open the temperature stays at ~165-170°F most of the time. No cycling.
Old 02-15-2019, 03:18 PM   #11
Smooth_One
Smooth_One's Avatar
I will see how it runs just by it self first but I am definitely considering it.
Isaiah B.
Old 02-15-2019, 03:20 PM   #12
Smooth_One
Smooth_One's Avatar
Thank you for the info! I did not know that but will keep an eye on it when installed.
Isaiah B.
Old 02-15-2019, 03:22 PM   #13
Smooth_One
Smooth_One's Avatar
I just ordered a 2 blade Aluminum fan and Super Leakless pump From Bert’s for the engine as well. I have the 4 blade aftermarket right now but you guys talked me into going back to the 2 blade instead.
I’m no Scientist but a couple of you on here said that the blades are angled just right on those and they push plenty of air as they are
Isaiah B.
Old 02-15-2019, 03:27 PM   #14
Smooth_One
Smooth_One's Avatar
The car will be at the Billetproof Florida show at Don Garlits shop next month and she should be happy and running just right by then!
Isaiah B.
Old 02-15-2019, 03:40 PM   #15
Benson
Benson's Avatar
Here is explanation of how SuperStat is different.
http://www.stant.com/index.php/engli...at-thermostat/
Old 02-15-2019, 04:08 PM   #16
Werner
Werner's Avatar
Hello,
is this intruduced one better than a tube-thermostat? If, why?
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 02-16-2019, 08:17 AM   #17
Joe K
Joe K's Avatar
What? No broken ears to contend with?
How can one be a Model A owner and not broken his ears?
Kidding of course. Ford design was a "work in progress" as evidenced by the three bolt Model B water-pump.
Joe K
Shudda kept the horse.
Old 02-16-2019, 08:52 AM   #18
Smooth_One
Smooth_One's Avatar
Joe K
Less broken = more happy driving hours! Ha ha
Isaiah B.
Old 02-16-2019, 08:54 AM   #19
Smooth_One
Smooth_One's Avatar
Originally Posted by Werner View Post
Hello,
Thanks for posting this link! Very informative WERNER.
Isaiah B.
Old 02-16-2019, 10:22 AM   #20
Benson
Benson's Avatar
Please tell me where I can find the link that Werner posted?
I do not see a link on Werner's post ...
Did I miss something?
