03-04-2013, 01:40 PM | #1 |
Leaking Side Timing Cover Gasket
I going to replace this gasket as well as the valve cover gasket. While the valve cover gasket is off is there any preventative maint I should consider ?
I have no problems other than the leaking side timing cover gasket. |
03-04-2013, 01:51 PM | #2 |
Re: Leaking Side Timing Cover Gasket
You could check your valve lash , look at your springs .
03-04-2013, 02:10 PM | #3 |
If you see any rust pits in any of the springs, including the oil pump drive, now is the time to replace them.
03-04-2013, 02:18 PM | #4 |
Sounds good. I subscribe to the "don't kick a sleeping dog" theory. Thanks I'll check the valve train out.
03-04-2013, 02:46 PM | #5 |
Also check the valve cover for cracks. I have had a cover that was a persistent "leaker" until I discovered that it had several cracks at two of the lower bolt holes. Gar Williams
03-04-2013, 02:50 PM | #6 |
Then ck the feed holes to see they are not blocked. |
03-04-2013, 02:52 PM | #7 |
Check to be sure that you have the copper washers under the two
bolts that hold on the drain tube. If no washers they leak! |
03-04-2013, 03:15 PM | #8 |
Hey thanks everybody - I'll check all that stuff out..
