03-04-2013, 08:52 PM | #1 |
Door Glass Size Confusion!
I'm replacing the door glass and channels on my '29 Tudor and have a questions for the experts. The Service Bulletin Book on page 250 indicates that the glass size is 25 7/16 - 25 1/2" width and 19 9/16 and 19 7/8" in height. The glass I removed from the car, which is plate glass, measures
26 7/8" width and 16 3/8" in height. I measured the new channel I installed and it measures the same width of the glass I removed, approx 26 7/8". If I was to have safety glass cut to the sizes noted in the Service Bulletins Book they would be way to small and flop around in the channels. Was the original channel thicker then the repo channel hence the smaller glass? What's up with the different sizes? Before I have new glass cut I'm planning to trial fit the glass I removed. If it fits without any binding or being to loose I'll have the glass cut to the same size as what I'm replacing. I'm just curious what's up with the different sizes...? Thanks |
03-04-2013, 09:28 PM | #2 |
Re: Door Glass Size Confusion!
Yes that's a Service bulletins mistake which has caught a few people.
The correct size off my NAGS chart is 26 3/4 x 16 1/8. If your original works well and you're keeping the same runs I'd keep the size exactly as is. Last edited by Craig Lewis; 03-05-2013 at 12:19 AM. |
03-04-2013, 09:58 PM | #3 |
I've already replaced the channel runs with reproduction pieces that seem to fit well and look good. I tried my existing glass in the channels and it seems to be a bit tight when moving the window by hand, no regulator. I'm wondering if I should have the glass cut to the dimensions you provided as it might fit a bit looser and not bind. Makes sense to me. Any opinions or comments?
03-04-2013, 10:47 PM | #4 | |
03-04-2013, 10:59 PM | #5 |
Yup, I know. Too loose will cause the glass to cock to one side and bind. If it's too loose I guess one can shim the channel so it tightens the fit a bit.
The glass I have is tight in the new channels. The glass is 26 7/8" in width. I'm thinking if the new glass was cut to what the NAGS says, 26 3/4" that might just be what I need for the window to operate as it should.??? |
03-05-2013, 12:15 AM | #6 |
I used the same chart to order my tempered coupe glass. It even has a pencil polished edge so you can't tell it apart from original plate ...sorry this page isn't clearer. Jan 1992 Restorer features this same list. |
03-05-2013, 10:19 AM | #7 |
I'm going over to a glass shop that does many 'old' cars. Chances are very good that they have done other Model A's in the past. I'll see what they have to say about the proper size and go from there. If only the car was running I could drive it over and have them measure and install the glass. Oh wait, this is part of the fun of owning an old car, isn't it? Yup, it is!
