08-07-2017, 12:11 PM | #101 | |
Re: Vacuum signal
Joe What cfm is that carb? And what color secondary spring is in the camber? Sent from my iPad using Tapatalk |
08-07-2017, 04:54 PM | #102 |
Re: Vacuum signal
08-07-2017, 04:56 PM | #103 |
Re: Vacuum signal
08-07-2017, 08:00 PM | #104 |
Re: Vacuum signal
I can appreciate the "stock w/blower" idea, but I was specifically speaking of the orderly and purposeful look of the way you have assembled ALL bits 'n pieces...........just NICELY done! DD
08-07-2017, 08:27 PM | #105 |
Re: Vacuum signal
Joe do you think the secondary's are coming in at the proper time??
I still say wire the secondary's closed and jet the primaries first and than add the secondary's in. At least if you know the fuel mixture is right with the primaries when you add in the secondary's you can jet the knowing the primaries fuel mixture is right. And if you want the secondary's to come in sooner or later you can change the spring. Sent from my iPad using Tapatalk |
08-08-2017, 04:06 AM | #106 |
Re: Vacuum signal
08-08-2017, 06:04 AM | #107 | |
Re: Vacuum signal
You're surely getting to know the carb, the tune and the engine - that is what this is all about! Great stuff! |
08-08-2017, 08:07 AM | #108 | |
Re: Vacuum signal
08-08-2017, 04:45 PM | #109 | |
Re: Vacuum signal
Thanks for your input Joe |
08-08-2017, 07:33 PM | #110 |
Re: Vacuum signal
Natural [standard] spring should be 6.5
08-09-2017, 02:30 AM | #111 |
Re: Vacuum signal
Where is your vacuum gauge plumbed in? Under carb or under blower?
Is it a combination boost/vacuum gauge? Sounds like it as you stated vacuum goes as soon as boost comes in. If it is it would be nice if you could plumb a vacuum gauge in under the carb and test drive. There is a situation where you can see boost under the blower but vacuum under the carb, this can shut the power valve. I'm asking as you're air/fuel is going leaner under boost, this can be solved by boost referencing the power valve, not sure if this has been covered yet. Martin. |
08-09-2017, 03:51 AM | #112 |
Re: Vacuum signal
08-09-2017, 03:59 AM | #113 | |
Re: Vacuum signal
I need to do some testing to see as I start to make boost, where my vacuum is. I know that in WOT, producing 4 lbs of boost I was showing leaner numbers around 14.4. Again, it's hard to tell exactly what's going on yet. I just need to get the time to drive!! Thanks, Joe |
08-09-2017, 08:59 PM | #114 |
Re: Vacuum signal
Hi Joe
The secondary's open on air flow through the primary Venturi With the blower everything changes so it is going to be trial and era. I like the secondary's to come in at about half throttle but that's a matter of preference. If you have the spring selection try a green spring that usually end up being my go to spring . Than you can try one up or one done like a white or natural but the one thing I always do is loose the check ball that's in the chamber. Have fun Pete Sent from my iPad using Tapatalk |
08-10-2017, 03:54 PM | #115 |
Re: Vacuum signal
Joe
14.4 is way to lean under boost I would fatten up the secondary's You are not looking for fuel economy your looking for performance, that being said afr should be around 12.7-13.2 on WOT. You would hate to have melted piston. Sent from my iPad using Tapatalk |
08-10-2017, 04:36 PM | #116 | |
Re: Vacuum signal
Here's my dilemma. Looking at the jet plate there are numbers cast in the bottom. "34R-9716B 3 Then there's a number stamped into the middle of the plate. This is where the confusion starts. I looked the number up in the instruction manual and it says a "6" equals a 69 jet. So I installed a 70 jet to test with. When I went on line to check this out, every picture of a jet plate that I saw had the stamped number upside down!! I called Holley tech and the told me it should be read right side up. If it's a "9" then I just jumped from a 67 jet to a 70. Is there a way to tell what the old jet plate actually is?? Thanks, Joe |
08-11-2017, 08:08 AM | #117 |
Re: Vacuum signal
Must've been a 69 jet plate because I test drove it last night with the 70's and there wasn't much of a difference. I'm going back to the 68's in the primary also because I think I'm still a little lean at cruise at about 15.6
08-11-2017, 04:00 PM | #118 |
Re: Vacuum signal
I just went through the video from last nights ride. I'm finding that in 5th gear, with light throttle, between 13-16 in. of vacuum, I'm between 15 and 15.6 A/F. I'm also leaning out at 3 lbs of boost, WOT at about 14.5 A/F and rising. It's obviously wanting more fuel!
Plan: Increase primary jets from 66 to 68 Increase secondary jets from 70 to 72 Increase power valve 8.5 to 10.5 And see how that goes. I may change the vac secondary spring to purple, which in the next size down from natural in my kit. |
08-11-2017, 04:17 PM | #119 | |
Re: Vacuum signal
My lightest is white, then there's two different yellows which they describe at lighter and light. Purple is medium light. Plain is medium, which is what I have in there now. Then brown and black. I'm thinking of throwing the purple in there to see what it does. Thanks, Joe |
08-11-2017, 07:35 PM | #120 |
Re: Vacuum signal
Joe
If you have no hesitation go for the light yellow spring,if you feel the secondary's are coming in to soon go for the purple. If the afr ratio stays around 14.1 I would go two jet sizes bigger on the secondary's and see if the ratio drops into the 13's Good luck Sent from my iPad using Tapatalk |
Thread Tools | |
Display Modes | |
