Old 06-04-2019, 08:21 AM   #1
ling102
Default Erratic idle
I have a 1951 Ford 2 door sedan, flathead 8, standard trans.The car has an electric fuel pump.
The idle is erratic. Any thoughts on smoothing the idle out?
Thanks guys.
ling102 is offline   Reply With Quote
Old 06-04-2019, 08:53 AM   #2
Mart
Mart's Avatar
Default Re: Erratic idle
Yeah. adjust the mixture, the idle screw and the timing. Make sure the carb matches the distributor. Make sure the diaphragm in the distributor works, make sure the points and condenser are good. Make sure the pump output is not too high pressure for the carb. Make sure there are no vacuum leaks around the carb and manifold and vacuum fittings for wipers etc.
Mart.
Old 06-04-2019, 01:56 PM   #3
supereal
supereal's Avatar
Be sure to check the throttle shaft in the carb for any play due to wear. This allows vacuum leakage, and interferes with the seating if the throttle plate. It is possible to have bushings installed to fix the problem, but usually carb replacement is less expensive. Also look for distortion of the mating surfaces of the carb body. This occurs when the screws are overtightened, and can result in leakage of air or fuel. Unscrew the idle needles and look for evidence of damage. Any of these conditions will affect smooth idle.
supereal is offline   Reply With Quote
Old 06-04-2019, 02:15 PM   #4
scicala
scicala's Avatar
If the throttle shaft is sloppy and leaking vacuum, these carbs never had bushings originally, and the shafts are what wears out more than the holes in the base. This is usually repaired with oversized throttle shafts which are available from Charlie ny on the Ford Barn. AKA: Charlie Schwendler (716)662-9159 [email protected]
Sal
scicala is offline   Reply With Quote
Old 06-04-2019, 02:31 PM   #5
ling102
I appreciate the time that everyone took to provide information and expertise in helping me with the idle problem with my car. I hope to be able to work on my 51 this weekend.
You guys are awesome! Thanks again.
Old 06-04-2019, 03:27 PM   #6
4dFord/SC
4dFord/SC's Avatar
Wasn't he a member of Monty Python?
4dFord/SC is offline   Reply With Quote
Old 06-04-2019, 06:27 PM   #7
19Fordy
19Fordy's Avatar
Plug wires and plugs are good?
Old 06-05-2019, 08:25 AM   #8
big job
big job's Avatar
You need a vacuum gauge they are cheap enough: As said above throttle shaft & bushings, point gap closed up, weak condenser, leaking valves, dirty idle passage's or
in general a dirty carburetor; did this just start? When was the last time it ran smooth?
Did it run fine with electric pump before or did you just install elec. pump? could be high
pump pressure these only need 2-3 lbs. if more pressure you would be 'drowning' it to
a point it would hardly idle at all. Then the pest, a leaking power valve ? Poor dist. cap
and or rotor? So the vac. gauge still rules. GET this; back in high school when these
V8's ruled the roads, we had a couple on test stands. diagnosis: the teacher would draw lines with a lead pencil inside of the distributor cap which drove the kids bonkers.
One really couldn't see said lines. I was the only one grown up in my fathers shop. So
I remember taking the cap off drop on the floor. whoops sorry, put another cap on then
it ran like a champ. And I did not get a A for that one cause my father taught me about
carbon tracks! sam
big job is online now   Reply With Quote
Old 06-05-2019, 02:19 PM   #9
Shoebox
Shoebox's Avatar
That's a good one!!
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 06-18-2019, 10:19 AM   #10
ling102
You guys are awesome! Thanks again for all the replies.
I am hoping to work on this soon. when I have the remedy I will post!
Old 06-18-2019, 12:31 PM   #11
joe 1950
joe 1950's Avatar
and a compression test will tell you if there’s a valve problem
joe 1950 is offline   Reply With Quote
Old 06-18-2019, 02:56 PM   #12
Charlie ny
X3 Sal and superreal
Charlie ny
Old 06-18-2019, 10:54 PM   #13
Mtn Wudy
Mtn Wudy's Avatar
Charlie........Thumbs Up ...
Whether you think that you can,or that you can't,you are usually right....H.Ford
Mtn Wudy is offline   Reply With Quote
