09-24-2017, 03:33 AM | #1 |
Distributor vacuum brake question
When the engine is at idol and the carburetor butterfly's are mostly shut would the distributor vacuum brake lift off as the manifold vacuum is high?
And when you are driving and butterfly's open the manifold vacuum will be lower and cause the spring to force the piston to act on the cam and weights to advance the timing? |
09-24-2017, 05:31 AM | #2 |
Re: Distributor vacuum brake question
It works like you say with the vacuum lifting the plunger but you can design for increase or decrease of timing so no issue there, the brake plate holds the centrifugal weights back when actuated by the plunger retarding the timing.
09-24-2017, 06:21 AM | #3 |
The spring actuated plunger has a leather-like pad. At lower vacuum the pad rubs on the rotating plate and resists the mechanical advance. It does not retard timing, but rather, delays the application of advance.
09-24-2017, 09:25 AM | #4 |
It is a vacuum controlled retard system to act as a brake on the advance disc under load conditions. It only has braking affect when manifold pressure is high (low vacuum) as was stated. A person can say that it doesn't physically retard the timing but in effect it does so by slowing the advance mechanism.
09-24-2017, 10:42 AM | #5 |
My chart from a old Ford training guide says :
Governor weights spread as speed increases thereby advancing spark. The same vacuum force that operates your windshield wipers also retards the ignition spark. As i run one of these almost every day on a machine. I would explain it like this: Engine off leather brake holds the advance ring by spring tension causing a slight retard in timing allowing a easier start. Once the engine starts vacuum pulls brake off the advance ring allowing a proper advance as soon as the engine starts. Driving down the road and hitting a hill (increase load) vacuum will drop off causing a retard to timing preventing spark knock. There are some good pictures on our web site http://www.bubbasignition.com/crab-42-48.html I guess its how you word it????? |
09-25-2017, 05:41 PM | #6 |
I unscrewed the plug in the shaft like bubbas website recommended and oiled the wick. Got a pertronics electronic conversion and am putting that into a 2nd distributor, |
01-18-2020, 04:11 AM | #7 |
I set my distributor up in the timing fixture and set that scale on the side witch the fixture, I am thinking I could advance it a lot more as its at half now
01-18-2020, 03:27 PM | #8 | |
Normally set with 1 division advance ie 2 degrees static advance. Unless your actual timing is not correct. Road testing normally confirms you have this correct. Phil NZ |
01-18-2020, 05:07 PM | #9 |
The flyweights move out at rpm to give most of the advance. It does have to be set for starting though. Once it's set, it should need no further adjustment.
Last edited by rotorwrench; 01-19-2020 at 12:28 PM. Reason: correct doesn't to does |
01-18-2020, 08:54 PM | #10 |
Are you saying, just back off the vacuum brake totally and let the breaker plate run without a brake?
01-18-2020, 09:16 PM | #11 |
01-19-2020, 01:17 PM | #12 |
Manifold vacuum pulls the plunger away from the plate. So during normal everyday driving the plunger does not contact the plate, so I don't see how it can stabilize the timing. If you've got wobble, the distributor needs to be serviced.
01-19-2020, 01:40 PM | #13 |
There a lot of disagreement as to the purpose of the vac brake . Most very untrue.
Heres what actually happens in slow motion : ( assuming vac brake is properly adjusted) You can see this action on a distributor machine . Engine off = no vacuum , piston is spring loaded down to the spark ring . Leather is pushed against ring. Engine cranking = very low vac piston is still forced inward , causing a slight timing retard. ( desired) Engine starts, manifold vacuum is increased ( above spring tension) piston moves off the ring allowing some advance as engine is now running. Then driving down the road hitting a large hill etc vac again drops allowing the leather to again drag making the spark retard slightly.. I actually have this somewhere in a old ford training manual, will look it up as time goes on. |
01-19-2020, 02:48 PM | #14 |
I understand the operation, it is just that I cannot see how the plunger is said to stabilize timing.
01-19-2020, 03:01 PM | #15 |
watching the spark timing on a distributor machine without the piston the spark lines kinda jump from side to side at idle. These units dont ever show wear and even a new one shows the same looseness. ( they would need to be loose to work). When piston and leather with some spring tension on the ring the spark lines are very stable on the machine , would be the same using a timing light on the pulley. Just something we have noticed , i seems to learn something on every rebuild and test .......
01-19-2020, 05:39 PM | #16 |
The only time I've seen that on my machine is when the distributor is worn. At idle, the vacuum is high so the piston is away from the ring.
01-19-2020, 05:46 PM | #17 |
On my cars I have the vacuum line plugged and use only slight tension on the piston. Personally on today’s fuels I don’t think the vacuum brake function is needed on a stock flathead engine.
