Old 12-04-2021, 09:40 PM   #1
Shoebox
Shoebox's Avatar
Default 1951 fan assembly
OK, I am assembling the needed drive line parts to convert my newly acquired '51 Tudor from 6 cyl. to flathead V8. I did this about 20 years ago to a similar car, some details I need to refresh. Regarding the cooling fan, what is the correct narrow belt fan assembly?? Thanks!
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 12-05-2021, 07:04 AM   #2
Mac VP
Mac VP's Avatar
Default Re: 1951 fan assembly
Except for special service vehicles, all Ford passenger car V8’s used the same 3 bladed fan assembly with the narrow groove pulley. I think it had the 8BA-8602 part number. This was one complete assembly that included the fan blade, hub and sheave, and mounting bracket. The fan blade was riveted the hub. The bearing was a dual sealed ball bearing and it was not a service part sold by Ford. However , there’s an aftermarket shaft and bearing assembly from a common water pump that can be made to work.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 12-05-2021, 09:40 AM   #3
Shoebox
Shoebox's Avatar
Thanks Mac, I'll probably pm you on this.
32 Ford roadster
39 Mercury Towncar
