Old 10-14-2018, 09:32 AM   #21
5851a
Default Re: Carpet Purchase Advice, Fiasco
Originally Posted by JeffB2 View Post
You might want to check out some install tips. https://www.jefflilly.com/build-tips/carpet-install/
That is insightful, rather extreme amount of work for something that should drop in. Back in about 1980 I had to replace ripped carpet in a 78 LTD, ordered it from Ford and it just fell into place, fit like a glove.
5851a is offline   Reply With Quote
Old 10-14-2018, 10:27 AM   #22
KULTULZ
KULTULZ's Avatar
Post Re: Carpet Purchase Advice, Fiasco
One would have to have the original FORD (supply vendor) patterns and molds (if any). That would require the carpet be registered with FORD so they can get their cut, which is more than fair.
Auto Custom Carpet has the factory press molded set available for most cars, but they do not drop in very easily as we will see. We always order it untrimmed so it is usually six inches wider and longer. This allows us to cover more area, especially higher up on the fire wall so you can not see the edge standing outside of the car. We often order the carpet without the jute padding as we prefer to do our own padding. On some projects we use a combo by removing the jute where we do want it and adding more pad on the areas we need it.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-14-2018, 11:13 AM   #23
rotorwrench
rotorwrench's Avatar
A friend of mine worked for Jeff for several years. I bet that carpet job ended up being very expensive. Good trimmer tips though. They fit plain flat carpet using the same methods with some exceptions.
Old 10-15-2018, 12:01 PM   #24
Jwawhite
Jwawhite's Avatar
Okay, here's an update, I called the Company directly, perhaps I responded poorly when I retorted "we're story" to their "we're sorry" and the line was suddenly disconnected....but before then I got across how poorly the carpet fit especially over the hump areas just aft of front seat all the way back, two pieces. If the ends were too long, I could have just cut them but when there's excess at the hump forget it. I'd need some sewing equipment in my garage, I don't. Previously I mentioned to them the front piece didn't fit that well (see above pic) but I'd live with it. Lastly I reported the lack of a finish seam for the third piece. Forgot to ask about the missing? jute pad for the rear section of car. The last didn't matter for I put in upgraded material. Don't understand why the Company thinks one doesn't need jute pad under the third piece of carpet. Okay so I sent word to the Parts house I bought the carpet from and suggested they may not want to sell this carpet. Response? No refund for the carpet is mounted in car. What?? I never asked for a refund! Just nuts all around.
Jwawhite is offline   Reply With Quote
Old 10-15-2018, 02:38 PM   #25
delco1946
delco1946's Avatar
I ordered carpet for my 1955 crown Victoria, but had it professionally installed. It wasnt the best fit, but not bad enough that the installer talked to me before installing it. And it isn't so bad that it really bothers me. Its about .5 inches too wide and rides up the driver side front quarter panel. I figure that at the rate the carpet fuzzes up i'll probably end up replacing it again in 5-10 years so i'll get it right then *shrugs*
delco1946 is offline   Reply With Quote
Old 11-20-2018, 07:38 PM   #26
Roothawg
Roothawg's Avatar
I am struggling with this now. I swear it looks like Stevie Wonder sewed this up. Does anyone other than ACC sell carpet for a 55 Ford Customline?
CrossMembers CC SW Regional Rep
Roothawg is offline   Reply With Quote
Old 12-01-2018, 12:34 PM   #27
Jwawhite
Jwawhite's Avatar
That product/company is messed up. They offered a partial? refund, I didn't bother. Next time an upholstery shop that supplies its own product.
Old 12-01-2018, 04:05 PM   #28
KULTULZ
KULTULZ's Avatar
Thumbs down Re: Carpet Purchase Advice, Fiasco
In other words, NO REFUND PERIOD and they just don't care they are selling JUNK.
That's the trouble with buying over the internet, you have very little recourse.
- WHY IS IT ... -
Old 12-02-2018, 09:34 AM   #29
Ford blue blood
Ford blue blood's Avatar
ACC is out of Anniston, AL. I have used them exclusively over the years. Yes the carpets require a little finagling but they have all settled in and look great when installed. Here are a few shots of the carpets I have installed from ACC.
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 12-02-2018, 03:10 PM   #30
Jwawhite
Jwawhite's Avatar
Finagling? Great word.
Old 12-03-2018, 05:53 PM   #31
Daves55Sedan
Daves55Sedan's Avatar
My '55 car had carpet in it originally. There was nothing left of the carpeting where the drivers feet go, so I ripped out all the carpeting. The front doors and windshield leaked rainwater in so the carpet was often soaked. Back then, J.C. Whitney & Co sold custom molded to-fit full coverage front floor mats. I bought one of theirs and used it for about thirty years. After it cracked up and was falling apart, I ripped it out and bought a new one from the Ford Parts store (no longer in business?) and still using it although now it is beginning to show some cracks.
Carpet is nice but it can hold moisture. You drag it in on your feet, rain, snow and ice. No wonder I have had to replace the driver floorboard twice.
When I built the '55 Courier wagon, I got another rubber floormat, this time from Concours Parts. The wagon doors leak rainwater also, so I installed the floormat without the jute backing. My feet sizzle on the floor during any long trip in the summertime. But it is dry.
Daves55Sedan is offline   Reply With Quote
Old 12-03-2018, 09:06 PM   #32
rotorwrench
You have a good point about moisture. Ford coated the floors with a tar based stuff that cracks & traps moisture between it and the floor pan. This is why so many cars of the era have such crusty floors. A person should put a moisture barrier between the carpeting and the metal. Primers and paints were not something that Ford used on the floors much since their coating was supposed to do the job. It did fine for about 8 years and then it became a detriment and especially so if carpet was used. A good quality primer and paint would help a lot. Add the high dollar sound deadener pieces in and it should do pretty well as long as the sound deadener doesn't pass moisture through.
The other alternative would be to leave it in the garage when it's wet outside.
Old 12-04-2018, 10:38 AM   #33
bobss396
bobss396's Avatar
I have Fat Mat Rattle Trap mat under my carpet. My OG floor must have had the rubber mat on it, it was pretty clean as is. Mine is in the garage all year and I try not to drive it in the rain. My ACC carpet job is acceptable, it was only 2 pieces and the rear part fit perfect.
bobss396 is offline   Reply With Quote
Old 12-04-2018, 05:02 PM   #34
Daves55Sedan
Originally Posted by rotorwrench View Post
You have a good point about moisture. Ford coated the floors with a tar based stuff that cracks & traps moisture between it and the floor pan. Primers and paints were not something that Ford used on the floors much since their coating was supposed to do the job.
I have torn out interiors of many 51-57 Fords. All the floor pans were treated the same way. Primer, base enamel coat (same as base color of exterior of car), then poured in seam sealer at the seams and most of the floor recesses (to prevent floorcovering from sagging in to them). There was never any tar coating over the enamel paint. As I recall, most of them did have some type of tar-paper (similar to thin roofing felt under the jute backing and floor-covering, which was badly disintegrated by the time I got into it.
No matter which way you go; carpet or rubber mat, you are going to have water in contact with the metal. But carpet is like having nothing against water penetration.
After I had cut out and welded in all new floor panels, I sprayed the entire floor with acid etch, then I used a quality caulk for seam sealer. I primered the floor and sprayed two coats of base enamel. Next I cut out my own custom fit roofing felt, covering the floor completely and overlapping at seams. No jute, no sound deadener (as I feared these would hold moisture and create mold and cause rusting). But I suffered for it by having sizzling feet in the summertime.
That might have been reduced by keeping the muffler isolation panel under the floor, but it was not salvageable and I did not make a new one.
I have a one space garage and always keep one of the cars in there. The car I usually drive daily sits outside. Doesn't really matter. If you got the doors and windshield sealed good, you may not get leakage that way, but you will still drag rainwater, ice, snow, etc in onto the floor with your feet. I drive my cars daily, regardless of weather. That's what my car is for. This moisture thing is just something that you are never going to get perfect. You can reduce it and protect against it quite a bit though.
Old 12-04-2018, 08:50 PM   #35
Jwawhite
Jwawhite's Avatar
Originally Posted by Roothawg View Post
I am struggling with this now. I swear it looks like Stevie Wonder sewed this up.?
Attachment, missing front edge trim, edge trim area no where near bolt up area of rear seat, both pieces, lower seat that swings up or the seat back piece.
Perhaps wagons are not their forte.
Don't do what I did, running out of time, not inspecting product.
Great humor!
Old 12-04-2018, 11:08 PM   #36
Daves55Sedan
JWA, I have done two body-off-frame restorations, each one taking four years to complete. During the projects, I would buy repro parts that I knew were going to be needed, but might not be ready to install until months down the road. There were a few cases where new parts either didn't fit or didn't last long after the installation. But with the passage of time while that stuff sat waiting, the 30 day warranty was expiring, so I got screwed on a few things. It happens, so don't feel bad.
Old 12-05-2018, 07:41 PM   #37
rotorwrench
[QUOTE=Daves55Sedan;1702280]I have torn out interiors of many 51-57 Fords. All the floor pans were treated the same way. Primer, base enamel coat (same as base color of exterior of car), then poured in seam sealer at the seams and most of the floor recesses (to prevent floor covering from sagging in to them). There was never any tar coating over the enamel paint.
It may have only been the 49 thru 51 Mercury cars that had the tar coat. I have two 51 cars and both had the coating over the whole floor pan in the cab. One car had factory undercoating and the other didn't so I imagine it was optional on those cars or added by the dealer on the one. The floors have evidence of primer only on the metal that didn't get rusty higher up from the floor level. The trans hump cover was painted black but the floors only had red primer.
Both cars came from the Saint Louis plant. Only several weeks apart. My hand me down car spent most of its life in southwestern KS. The other car spent its early life in eastern NM so both cars came from dry country. The NM car was only primed underneath with red oxide primer and it is still in pretty good condition for a Mercury of the era but has rusty floor due to carpet & jute. The hand me down with the undercoat rusted real bad underneath due to the undercoat but the interior floor is in good condition due to being equipped with the brown rubber floor mat. It's always one thing or the other with these cars.
The exterior of the 51 Mercs were painted well enough but the interior, underside, and all the hidden areas in the rockers, inner rockers, and doors rusted like hell due to little or no priming in those areas. I have an NOS door that just has the tar based sound deadener sprayed inside. The only prime it got was from over spray coming in from coating the outside. The sound deadener was sprayed after the priming process. It was a b!tch cleaning the remnants of the sound deadener off in order to do metal repairs. It flaked up in the rusted spots real easy but was hard as a rock on the vertical surfaces.
Ford cars may have had a different treatment but I haven't worked on too many shoe boxes. A 1953 Mainliner 4-door a friend of mine used to have was pretty much as you describe. It rusted a lot less too but it had some cancer on the exterior entrapment areas.
