Old 05-05-2014, 08:18 AM   #1
mrraford
Default Double Arm Window Riser Spring?
The joys of the less than common Model A!
The drivers side window riser large spring on my 68C door is broken. I was wondering why it was so difficult to crank the handle....now I know.
I don't have a regular window riser for comparison but it appears similar to the regular riser springs.
Does anybody here that knows Vicky's, slants or 68Cs know whether the regular large spring sold by the suppliers will work for the double arm device? Or do you know a source for these?
mrraford is offline   Reply With Quote
Old 05-05-2014, 10:03 AM   #2
jw hash
jw hash's Avatar
Default Re: Double Arm Window Riser Spring?
I to would like to find a good source for the springs. I have been looking for years, no one that I can find makes the correct springs. and no other Model a regulators uses the same spring as the slant window two arms regulators. I bought regulator Roy out of the ones he had a couple years ago. I have reworked a lot of the two arm regulators and I do have a large spring that I can part with.
John Hash 206 730 0047 or [email protected] .
jw hash is offline   Reply With Quote
Old 05-05-2014, 11:10 AM   #3
Doug in NJ
Doug in NJ's Avatar
I needed one of those springs. Fortunately Bert's in Denver was able to supply me with a good used one.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 04-04-2018, 09:24 PM   #4
Bud
Bud's Avatar
To resurrect this thread: Can anyone give me specifications on this spring? For example, some dimensions regarding width of the spring, thickness of the steel, number of turns, perhaps the radius of the hook on the end or any other pertinent data? I know a vendor to get a quote. Also, how many folks may be interested? Thanks.
Bud is offline   Reply With Quote
Old 04-05-2018, 10:00 AM   #5
burner31
burner31's Avatar
I had the same problem, used a spare spring from my '57 Chevy, you can see it in the pic, it's the bigger spring.
It worked for awhile but it finally started to tear the spring tab on the regulator plate, so, damage done.
Moral of the story is: Other springs may work, for a while, but if it's to strong a spring it can cause more damage down the road.
Was saved/helped by a fellow Ford Barner, who set me up with a repairable regulator...you know who you are because you've repied to this tread.
Thank You again.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 04-05-2018, 10:45 AM   #6
Dave in MN
Dave in MN's Avatar
I omitted the original info in this post. Snyder's states they have a spring...but apparently it is not the correct one as burner31 points out in the following post.
Thanks Keith for pointing it out.
Good Day!
Dave in MN is offline   Reply With Quote
Old 04-05-2018, 11:56 AM   #7
burner31
burner31's Avatar
That's not the correct spring that fits to the regulator plate
Keith
Shawnee OK
'31 SW 160-B
Old 04-05-2018, 08:36 PM   #8
Bud
Bud's Avatar
How about this idea: can someone share a broken spring for the slant window regulator with me? That way I can measure it, get an idea of the width, number of turns, how the hook at the end is made, and perhaps get the material tested to see what tensile strength it was. Or if someone can post the original detail of the spring I could perhaps ask for a quote on this item. Thanks.
Old 04-05-2018, 09:39 PM   #9
burner31
burner31's Avatar
I have a broke one in one of my boxes, let me find it and I will gladly send it to you.
Will PM when I find it.
Keith
Shawnee OK
'31 SW 160-B
Old 04-06-2018, 11:22 AM   #10
Bud
Bud's Avatar
If you can find both pieces that would be the best. Thanks!
Old 04-07-2018, 01:08 AM   #11
jw hash
jw hash's Avatar
there is two different size springs on the two arm regulators. and NO vender that I know of sells they.
Old 04-15-2018, 08:42 AM   #12
burner31
burner31's Avatar
Well i can't find that damn spring, but I'm going to keep looking.
When I do find it, and I will, I'll PM and send it to you
Keith
Shawnee OK
'31 SW 160-B
Old 04-15-2018, 01:50 PM   #13
Bud
Bud's Avatar
OK, no rush. I have a lot of other projects at this time. Based on jw hash's reply, I probably need the specs on both springs if possible. I cannot guarantee I can get the vendor to help me out with this, so all I can do is ask.
Thanks everyone for your help.
Old 04-15-2018, 09:48 PM   #14
SteveB31
SteveB31's Avatar
We have a handful of them, if you still need one.
Steve Becker
Bert's Model A Center
email me at [email protected]
SteveB31 is offline   Reply With Quote
Thread Tools
Display Modes
