08-28-2019, 07:46 PM | #1 |
Any idea what tis frame is?
It has wide five wheels and cable brakes like 37-38 Ford but what is it?69045375_10157377635464223_3846931756678643712_n[1].jpg
Tommy |
08-28-2019, 07:57 PM | #2 |
Re: Any idea what tis frame is?
HD wagon. Look at that front spring.
08-28-2019, 09:53 PM | #3 |
looks like the front frame rails are pinched in. i cant guess why, but i have had lots of farm wagon frames and never seen that before.
08-29-2019, 08:13 AM | #4 |
I'll take a stab at this: Hydraulic brakes so 1939+. Heavy frame so perhaps 1 ton+.It's certainly not passenger car.
Perhaps measure the wheel base for us? Maybe find the serial number???
08-29-2019, 08:41 AM | #5 |
Kube, believe the brakes are cable, not hydraulic.
08-29-2019, 09:41 AM | #6 |
08-29-2019, 10:06 AM | #7 |
Maybe a commercial with passenger car axles? But then.. Didn`t commercial trucks have parallel leaf springs in the back?
Tommy |
08-29-2019, 11:07 AM | #8 |
If your lucky the wide fives are 18" instead of the normal 16" ones.
08-29-2019, 01:56 PM | #9 |
It's a wierd one, It probably was something made up from parts that didn't go together originally. The frame looks commercial but has a deep drop in the centre. A farmer could have spent a couple of days welding that up from whatever was handy. The front U bolts are inverted, the rear has coils added (only one showing).
Mart. |
08-29-2019, 02:06 PM | #10 |
How about a Lincoln with the body cut off? Looking at the front and rear crossmembers it appears to have been built with those.
Tommy |
08-29-2019, 02:15 PM | #11 |
I REALLY need my eyes checked. You are correct.
Yikes, I'm calling the doctor now.
08-29-2019, 02:31 PM | #12 |
08-29-2019, 08:29 PM | #13 |
Lincoln about a 1936
08-29-2019, 08:37 PM | #14 |
08-30-2019, 02:12 AM | #15 |
We have a winner. It was for sale on the HAMB a couple of years ago: https://www.jalopyjournal.com/forum/...parts.1078525/ - |
08-30-2019, 02:58 AM | #16 |
Good sleuthing guys.
08-30-2019, 08:59 AM | #17 |
Interesting, so Lincoln was using cable brakes in 36.
08-30-2019, 09:35 AM | #18 |
Self energizing, too.
08-30-2019, 09:39 AM | #19 |
Thanks Rich, that arrangement looks very modern! To bad Ford didn't switch over sooner to both hydraulics and self-energizing. I understand Henry's resistance to hydraulics because he didn't use it first, but don't get the Lockheed vs Bendix. Did Henry have a personal issue with Bendix?
