Old 03-12-2019, 02:59 PM   #1
nick c
Default body blocks and frame webbing
my 29 cc AA has the body blocks, is there supposed be any frame webbing or anti squeak, between the blocks and the frame and sub frame? thanks
nick c is offline   Reply With Quote
Old 03-12-2019, 04:06 PM   #2
Steve Plucker
Default Re: body blocks and frame webbing
Just between the frame and fender/splash aprons.
Pluck
Old 03-12-2019, 04:43 PM   #3
100IH
And rubber tacked onto the bottom of the block in the frame contact area. Any shimming would be additional rubber held in place by the bolts passing through a hole in shim.
100IH is offline   Reply With Quote
Old 03-12-2019, 07:34 PM   #4
Dan Partain
Dan Partain's Avatar
Here are some photos of body blocks. The rubber on the block goes down against the top of the splash apron. The splash apron is sitting on the frame webbing, the frame webbing runs from the front of the frame along the frame to the end of the splash apron and ends.
You can read more about the frame welting "anti-squeek" here on Plucks website -
http://www.plucks329s.org/pdf/studie...EAKARTICLE.pdf
Dan Partain is offline   Reply With Quote
Old 03-13-2019, 04:50 PM   #5
Neil Wilson
Neil Wilson's Avatar
For the AA with 82-A closed cab, the anti-squeak (frame webbing) runs under the front fenders and running board shields to where the shields leave the frame. In the attached, I ran the welt a little further and put welt on the body bracket to make it level with the frame.
There are rubber pads under the cowl sides where the front body blocks are. The other body blocks have a rubber pad attached to the block (between the frame and block). No pad or webbing on the top side of body blocks. Use pads reinforced with webbing (otherwise, plain rubber pads will just compress down to nothing).
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
