03-06-2019, 03:25 PM | #1 |
Removing a 32 5- window pass door latch
I have it almost out but the glass metal channel (and felt channel?) is/are in the way of removing it.
What needs to be done from this point? Window is still in - you can see that the interior of the spring is broken and the second pic shows the screw I think I need to remove to get the metal window channel piece out of the way and jockey out the latch. Do I need to remove the felt channel completely? Thanks for any help you can give ...... |
03-07-2019, 12:51 AM | #2 |
Re: Removing a 32 5- window pass door latch
Generally the rear verticle felt channel must be removed. I used to make them ,but now United pacific has them, very cheap and they fit well. Same on the Pickups must be removed. Newc
03-07-2019, 07:57 AM | #3 |
Thank you ..,,
03-08-2019, 01:14 AM | #4 |
