Old 09-15-2019, 06:25 PM   #1
artron9
Default Holley 94 accelerator pump helper spring
i'd like your opinions regarding a spring that sits in the well of a Holley 94 carb. Not to be confused with the spring that is part of the accelerator pump itself. Some rebuilders use this and some are against it. It can be a conical spring that helps the accelerator pump return to its normal position. Ford does not show this part in their drawings. I know Ken CT. does not advocate its use. Any other opinions?
artron9 is offline   Reply With Quote
Old 09-15-2019, 07:22 PM   #2
tubman
tubman's Avatar
Default Re: Holley 94 accelerator pump helper spring
All I can add to this is that the Ford engineers rarely added anything to their automobiles that was not needed. And, if they did, Henry would have quickly shut them down. As to your last statement? Consider the source.
Old 09-16-2019, 12:34 AM   #3
ford38v8
ford38v8's Avatar
I'm with tubman on all points.
Alan
Old 09-16-2019, 06:19 AM   #4
mfirth
Tubman x 3....but, ask Charlie NY with a p m. He seems pretty sharp on these carbs.
mfirth is offline   Reply With Quote
Old 09-16-2019, 11:21 AM   #5
scicala
scicala's Avatar
I've seen that spring below the pump piston in a few carbs. I agree it's not in any parts drawings. If the hole in the throttle lever for the pump link is worn (or the pin on the link is worn) it can cause some slop and the throttle will move slightly before the pump piston goes down. The helper spring can help take up the slop and make the pump react quicker. That's the only advantage I see to the spring. Also it doesn't hurt anything being in there.
Sal
Old 09-16-2019, 12:34 PM   #6
artron9
Thanks guys for your input! If ford didn't think it was necessary neither do I!
Old 09-16-2019, 06:08 PM   #7
tubman
tubman's Avatar
I think you may have mis-understood my comments. Every 94 I have taken apart had that spring in it; therefore it was probably necessary. Sorry, I can see how my response was unclear.
Old 09-16-2019, 06:25 PM   #8
flatjack9
flatjack9's Avatar
I also use it.
Old 09-16-2019, 08:33 PM   #9
Charlie ny
No harm, just don't leave out the check ball retaining clip.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 09-17-2019, 03:17 AM   #10
Mart
Mart's Avatar
I've had a few 94s and never found a spring under the accelerator pump plunger.
Mart.
Thread Tools
Display Modes
