Old 09-14-2019, 08:16 PM   #1
sethkestenbaum
sethkestenbaum's Avatar
Default Phaeton Front Seat Removal
I have to re-upholster the front seat in my phaeton. Are there any tricks to remove the existing seat?
Seth
Seth Kestenbaum
www.oldcarroadtrip.com
sethkestenbaum is offline   Reply With Quote
Old 09-15-2019, 01:25 AM   #2
Synchro909
Synchro909's Avatar
Default Re: Phaeton Front Seat Removal
The cushion just lifts out. The squab requires a little umpicking around the back for removal.
Life's journey is best undertaken slowly.
Old 09-15-2019, 06:55 AM   #3
sethkestenbaum
I should have specified that it is the backrest that needs to be removed.
Seth Kestenbaum
Old 09-15-2019, 12:59 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
The backrest spring rests on a set of clips. You will probably need to remove the Hidem and tacks from the wooden seat tackrail, then lift the entire backrest upward.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-15-2019, 03:44 PM   #5
woofa.express
woofa.express's Avatar
To provide more wriggle room up front?
Every person that drives a 28 or 29 Tourer knows the difficulty in climbing in and out of the front seat. Since the seating is in question please let me ask another relative question starting with an explanation. I have modified my ute by replacing the inner spring seat back with a foam biscuit about 2 inches thick and then pushing the squab under and back. Not perfect but much improved. My Tourer, I had an upholsterer remove the rear set of squab springs and stitch up the cover.A little better but still ordinary. Of course with both I modified the wooden squab mount to allow more room to fit my feet through. Both the Ute and Tourer have different panels at the rear of the front seat; the ute being square and the Tourer being rounded at the ends. I am wanting to remove the Tourer seat back, the inner spring support and replace likewise with a 2 inch foam back but it is not as easy as the Ute because the Tourer does not have a square seat back.
For Tourer read Phaeton and Ute read Pickup.
Is there any suggestions from readers?
I know many things,
But I don't know everything,
Sometimes I forget things.
But at times I have a long memory.
woofa.express is offline   Reply With Quote
Old 09-15-2019, 05:59 PM   #6
BRENT in 10-uh-C
While I have no experience with an export body, I have relocated the rear seat panel rearward on a US version with great success. I have been working on a project of manufacturing smaller diameter steering wheels for Model-As that still look reasonably correct. A smaller steering wheel design would make easier to slide through. Even with the seatback moved rearward, the process of sliding in/out is still difficult with the full-sized wheel.
BRENT in 10-uh-C
Old 09-16-2019, 03:13 AM   #7
woofa.express
entry and exit by sliding beneath the steering wheel is difficult and I haven't thought much about that aspect. I am about to replace my 7 tooth steering box with a 2 tooth or '35 steering box. I had intended to change support of the column from the fuel tank to the body with a simple bracket one can purchase. I had not considered the difficulty of the changed entry/exit space but will have a look at that now it has been bought to my attention. Yes, if I am to proceed, a smaller steering wheel may be in order. thankyou, gary
I know many things,
Thread Tools
Display Modes
