Old 09-12-2019, 01:18 PM   #1
RalphG
RalphG's Avatar
Default 52 Rubber Bump Stop
On the top of the frame under the top suspension arm there is a missing rubber bump stop on my 52 Merc. Shocks are new but on occasion the suspension arm will bottom out on the top of the frame making quite a bump. I'm guessing new rubber is available but how big a job is it to install? Hoping it will just press in from the top but thinking possibly the coil spring has to come out to get the job done. Picture of where it is supposed to go.
I see they have it at C&G Ford. https://cgfordparts.com/ufolder/show...s=6&g=57&t=323
RalphG is offline   Reply With Quote
Old 09-12-2019, 01:37 PM   #2
40cpe
40cpe's Avatar
Default Re: 52 Rubber Bump Stop
My experience with that type of bumper is to lube it with silicone or rubber lube then twist and push it in the hole to the grove in the bumper. Being a farmer, I'll bet you can get it done.
40cpe is offline   Reply With Quote
Old 09-12-2019, 07:41 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Just plugs into the hole.
I have always used just soapy water to install.
51 MERC-CT is online now   Reply With Quote
Old 09-12-2019, 07:51 PM   #4
RalphG
RalphG's Avatar
Thanks for the info and pictures. Sounds like an easy fix once I order the new part.
Old 09-13-2019, 10:38 AM   #5
rotorwrench
rotorwrench's Avatar
If it is really stiff rubber, use some heat on it to warm it to 140 degrees F or so. The rubber becomes more pliable at higher temps. Make sure it fits the size of the hole there too. I've done these on my 51 and they weren't too bad to install.
Thread Tools
Display Modes
