Old 08-16-2019, 06:02 PM   #1
edhd58
edhd58's Avatar
Default independent front suspension
Someone somewhere has a bolt in independent front suspension for a 42-48 for car. It requires grinding off and removing the rivets that hold all the current front suspension parts in place. Then using the same holes all the new parts bolt right in place.
Does anyone know the company??
edhd58 is offline   Reply With Quote
Old 08-16-2019, 06:10 PM   #2
38bill
38bill's Avatar
Default Re: independent front suspension
Chassis Engineering which was bought out by Heidts a couple of years ago. I used the CE bolt on in my '38 truck and was very impressed with it. Its got to be very strong as it completely surrounds the frame rails. Speedway has a bolt in clone that looks not as strong to me. The web site doesn't show the bolt in so give them a call.
https://www.heidts.com/?ads_cmpid=94...SAAEgK4t_D_BwE
38bill is offline   Reply With Quote
Old 08-18-2019, 07:59 PM   #3
edhd58
edhd58's Avatar
looked at their catalog which I picked up at the Nationals in Louisville, it states there conversion is 3 inches narrower than the 42-48 Ford. I'm gonna keep looking for the one I have seen that is a direct bolt on to the chassis.
Old 08-19-2019, 06:43 AM   #4
rich b
rich b's Avatar
As far as I have seen the CE front end is the only "bolt-in" IFS kit that I have ever found for a '42-'48.
The 3" narrower track may not really be a detriment in the bigger scheme of things.
It is listed on the new (since Heidts) CE web sight.
https://chassisengineeringinc.com/pr...ab-description
rich b is offline   Reply With Quote
Old 08-19-2019, 08:57 AM   #5
uncle buck
uncle buck's Avatar
One of the for the suspensions narrow track width is after lowering the front, it helps to prevent the tires from hitting the fenders when turning
uncle buck is offline   Reply With Quote
Thread Tools
Display Modes
