Old 07-16-2019, 07:34 PM   #1
Doodlebug1930
Smile 28 tranny with multi-disc clutch
Can an early 28 transmission with multi-disc clutch be converted to be used with the more common clutch disk & pressure plate? Would it involve a lot of modifications? Thanks for any help.
Doodlebug1930 is offline   Reply With Quote
Old 07-16-2019, 07:51 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 28 tranny with multi-disc clutch
If you have a copy of the service bulletins there is a whole list including part numbers
Old 07-17-2019, 10:31 AM   #3
Mike Peters
Mike Peters's Avatar
I did that swap on an October 28 Tudor 30 years ago.
1. Replace multiple disc flywheel and clutch with the later single disc unit. Easy parts to find.
2.Replace your early bellhousing and transmission with the later unit. Also easy stuff to find. Your clutch pedal will work with the later bellhousing.
3. What's wrong with your multiple disc clutch?
Mike Peters is offline   Reply With Quote
Old 07-18-2019, 10:14 AM   #4
Doodlebug1930
The clutch is on a spare (barn find) transmission & is rusted up real bad with worn teeth. Have no plans to use the trans but just to keep as trading material.
Old 07-18-2019, 12:35 PM   #5
Joe K
Joe K's Avatar
Probably best to not do a thing to it. Sell it "as is-where is." Anyone who knows Multi-disks will know immediately the issues, understand what they're likely to get out of it, and trade/offer accordingly.
Many attempt to "upscale" items they have for trading purpose - but the act of "upscaling" for many buyers opens the specter of the unknown - and unknown usually decreases overall value.
I'd rather buy something "barn fresh" which hasn't been gone over by the owner, as barn fresh implies set aside for a reason - and most of the reasons are 1950 reasons. And not necessarily being sold for a reason.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 07-18-2019, 10:50 PM   #6
mrtexas
mrtexas's Avatar
I've done this. Everything connected with the transmission and flywheel must be changed including the pedal.
Palindromes:
Do geese see God?
Was it a car or a cat I saw?
Won't Neil call a Walla Walla client now?
Dr. Gong! Get ale to my motel at Egg-nog Rd!
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 07-20-2019, 07:09 AM   #7
Doodlebug1930
Can it be said that the early 28 transmission with the multi-disc clutch be left as a unique unit with its bell housing & flywheel as Henry built it. No point in trying to modify it.
Thread Tools
Display Modes
