Old 08-13-2019, 02:09 PM   #1
f balsiger
Question model a engine jumps time
checked distributor drive gear....ok camshaft next?
f balsiger is offline   Reply With Quote
Old 08-13-2019, 02:21 PM   #2
1955cj5
1955cj5's Avatar
Default Re: model a engine jumps time
Make sure you have the washers under the cam screw....the cam may be moving on the shaft...
https://www.brattons.com/distributor...with-hole.html
File Type: pdf distributor-exploded-view--newest-website-link--2351.pdf (432.0 KB, 27 views)
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-13-2019, 02:44 PM   #3
Benson
Please note that SOME repro screws are too long and the effect is same same missing a washer if used with original thin lock washer and original thin flat washer!
The screw bottoms out before the cam is tight.
The long REPRO screws come with an extra thick lock washer to correct this.
So if you use the long repro screw with original THIN lock washer and original thin flat washer the cam will slip.
Old 08-13-2019, 03:13 PM   #4
1955cj5
1955cj5's Avatar
Another thought...the cam itself has teeth on the bottom...perhaps yours is worn?
https://www.brattons.com/distributor-cam.html
Old 08-13-2019, 03:36 PM   #5
ursus
I had a Model A that jumped time every time I hit a bump or hit the brakes. I would then have to pull over and reset the timing again. I went over the distributor several times, switched to another distributor known to be good, but the problem persisted.
I later found that the spring inside the camshaft thrust plunger had broken due to rust. This allowed the camshaft to move back and forth resulting in variable ignition timing. When the timing was reset, the act of pulling back to take up slack on the distributor shaft moved the camshaft (and its drive gear) back to the correct position. After resetting the timing, the engine ran fine until I hit a bump, sneezed, scratched my bum, or had impure thoughts. Check that out as a possible cause.
Old 08-13-2019, 05:32 PM   #6
Synchro909
Synchro909's Avatar
FWIW, A friend was describing to me just yesterday that his engine with a high pressure oiling system would change timing as the distributor drive that goes into the valve chamber would move upwards due to the high pressure. The distributor/oil pump drive is held in place only by a spring and the extra load on the skew gear was enough to cause it to rise, thus changing the timing and he'd lose oil pressure because the drive to the oil pump would come apart. Once the timing was off far enough, the motor would slow and things go back to their normal place and function. It took him quite a while to work it out.
Life's journey is best undertaken slowly.
Old 08-15-2019, 06:07 AM   #7
ronn
unconfessed sin will get you every time!
lol
Old 08-16-2019, 11:09 AM   #8
Jim Brierley
I understand having impure thoughts, but it is unsafe to scratch your bum while driving!!! This from the CA DMV booklet. -
Old 08-16-2019, 04:18 PM   #9
40 Deluxe
And, DO NOT FORGET: "This action is known to the state of California to cause cancer, reproductive harm, warts and ingrown toenails." So stay out of California, and you'll be safe!
