Old 09-12-2018, 02:37 PM   #1
37 Coupe
37 Coupe's Avatar
Default Fan Blade advice.
I am putting a new radiator in eventually and since they are not so cheap and how my luck usually runs any advice on a reliable fan blade? I think mine is an original 1931 one it is two blade and it is attacted to a magnet so it must be cast steel or something besides the cast aluminum ones.Are they all subseptible to cracking and coming apart? Should I stick with the original 87 year old one and check for cracks or is the new aluminum ones the way to go.Thank You.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 09-12-2018, 02:53 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Fan Blade advice.
The new aluminum one is the way to go IMO. While you're at it I would recommend rebuilding/replacing the water pump. FWIW
Paul in CT
Old 09-12-2018, 02:59 PM   #3
37 Coupe
37 Coupe's Avatar
Thank you,yes I will be studying over the best water pump to buy also.
Old 09-12-2018, 03:00 PM   #4
Bob C
A lot of originals end up looking line this.
Bob
Old 09-12-2018, 03:28 PM   #5
37 Coupe
37 Coupe's Avatar
That is what I do not want near a new expensive radiator.Just trying to do stuff right especially with this.
Old 09-12-2018, 03:42 PM   #6
Charlie Stephens
Also use the fake "nut and stud" to attach the new pump so you can more easily replace it later if necessary.
Charlie Stephens
Old 09-12-2018, 04:37 PM   #7
Farrell In Vancouver
Farrell In Vancouver's Avatar
I had an original on my 28 Special coupe that I bead blasted and inspected with a magnifying glass. I could not detect a flaw or a crack. I repainted it and installed it and ran it till I lost a head gasket. Before reinstalling I checked it over very carefully and found some rust tracks. Bead blasted it again and found a series of hairline cracks emanating from the roots of both blades. It is now a wall hanger and I am glad it is just, that.
Cheers!
Farrell In Vancouver is offline   Reply With Quote
Old 09-12-2018, 04:50 PM   #8
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Just make sure the two tapers match. If not, the fan will wobble and fail. Not to tight on the belt too. All that belt load puts the tapered joint into bending.
Jacksonlll is offline   Reply With Quote
Old 09-12-2018, 05:15 PM   #9
WHN
Bob
Been there. You donít want this to happen to your car. Could do more damage than just to your radiator.
New two blade aluminum fan with leakless water pump. Two more potential problems taken care off. Enjoy.
WHN is offline   Reply With Quote
Old 09-12-2018, 05:52 PM   #10
37 Coupe
37 Coupe's Avatar
Also would like a water temperature gauge.Snyders and Brattons sell different setups for the temperature bulb probe.One is on the inlet on head.
Old 09-13-2018, 05:24 AM   #11
Jacksonlll
Jacksonlll's Avatar
I just put on the gooseneck. The other set-up makes that upper hose pretty stiff and you don't need any more loading of the radiator inlet, where they always fail.
Old 09-13-2018, 02:43 PM   #12
Lona
Lona's Avatar
If you're not going for judging points, use a plastic fan. I've had two metal blades crack.
Glen
'31 Model A Deluxe Roadster
'31 Chrysler Model 70 Sedan
'88 Pontiac Fiero GT
'36 Auburn Boattail Speedster replica
Lona is offline   Reply With Quote
Old 09-13-2018, 04:19 PM   #13
Charlie Stephens
Glen
What kind of metal, steel or aluminum?
Charlie Stephens
Old 09-13-2018, 07:07 PM   #14
37 Coupe
37 Coupe's Avatar
Just what I was wanting to ask.
Old 09-13-2018, 10:26 PM   #15
Mike V. Florida
Mike V. Florida's Avatar
ANYTHING EXCEPT ORIGINAL OR THE 60+ YEAR OLD FLAT BLADE STEEL REPLACEMENT. (yes I am yelling).
Old 09-14-2018, 02:36 AM   #16
juke joint johnny
juke joint johnny's Avatar
I had one of the Cast Iron hub bolted on steel fan blade ones throw a blade !!
Took out the radiator and broke the water pump casting,
More junk to be aware of!!
juke joint johnny is offline   Reply With Quote
Old 09-14-2018, 10:22 AM   #17
Lona
Lona's Avatar
Charlie Stephens
Both steel. One on a Model A and another steel 4 blade on our '31 Chrysler. When the A blade cracked, all suppliers I contacted to get a 2-blade alum fan were out of stock so I opted for plastic with the intention of replacing it later with an alum model. Two years or so later, haven't gotten around to changing it to alum since I'm quite content with the plastic one. Anybody have an alum fan crack and fly apart?
Glen
Old 09-14-2018, 01:41 PM   #18
100IH
Problem solved, aluminum is the way to go. Now, Water pump. get the parts to rebuild like original. Shop where the best parts are and save over $100.00 rather than "Upgrading". 30 years down the road when your old and wealthy buy the pump that you want now. Then when it fails in 2-3 years, get another std. kit and fix the original pump as a maintenance task. Use the nifty stud kit either way but use antisieze on threads.
100IH is offline   Reply With Quote
Old 09-21-2018, 12:26 AM   #19
Drive Shaft Dave
make shure you use a flat steel washer under the mounting nut on an aluminum fan.
Drive Shaft Dave is offline   Reply With Quote
Thread Tools
Display Modes
