Old 08-31-2018, 05:30 AM   #1
vern hodgson
Default Upholstery door panels
Regarding the map pocket in the door, was the cardboard door panel cut out for the map pocket or was it mounted on the surface. Meaning when you looked in the pocket could you see the cardboard panel?
vern hodgson is offline   Reply With Quote
Old 08-31-2018, 05:42 AM   #2
29spcoupe
29spcoupe's Avatar
Default Re: Upholstery door panels
The pocket on my Coupe is sewn to the surface of the door panel. If you look inside the pocket you will see the same cloth that is on the door panel.
29spcoupe is offline   Reply With Quote
Old 08-31-2018, 08:14 AM   #3
WHN
I have left them off. They always seem to sag and lose there shape.
WHN is offline   Reply With Quote
Old 08-31-2018, 09:07 AM   #4
ldreeg
ldreeg's Avatar
I've attached copies of an original late 1930 that show cardboard inside the map pocket
ldreeg is offline   Reply With Quote
Old 08-31-2018, 10:21 AM   #5
Cool Hand Lurker
Cool Hand Lurker's Avatar
Is that original door panel? It looks like there was a lot of heavy stuff in there for a long time.
Cool Hand Lurker is offline   Reply With Quote
Old 08-31-2018, 11:32 AM   #6
J Franklin
J Franklin's Avatar
That was your glovebox. How much stuff do you carry in your glovebox?
Old 08-31-2018, 07:14 PM   #7
vern hodgson
Yes, that is the same way mine looks. Seems kind of cheesy to look in there and see cardboard
Old 09-02-2018, 10:30 AM   #8
ldreeg
ldreeg's Avatar
It appeared to be and unrestored original car
Thread Tools
Display Modes
