Old 08-16-2018, 12:01 PM   #1
Paul King
Paul King's Avatar
Default Engine Squealing
1930 Town Sedan
I just reinstalled my engine after new flywheel, clutch, pressure plate, t/o bearing, water pump, rebuilt distributor, rebuilt carb, and timing gear. The engine started rough as expected but then started this screaming noise within a minute or two. I disconnected the water pump and generator to rule those out but still just squeals.
This is a YouTube video of what it looks and sounds like:
https://www.youtube.com/watch?v=IHjN4vqr-XA
Looking for any ideas on what I could have done wrong!!!
Paul King is offline   Reply With Quote
Old 08-16-2018, 12:04 PM   #2
JOHN CT
JOHN CT's Avatar
Default Re: Engine Squealing
Starter bolts hitting the flywheel? Maybe?
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 08-16-2018, 12:44 PM   #3
Marshall V. Daut
Ensure that the front pulley isn't rubbing against the front engine mount yoke.
Also, oil the distributor.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 08-16-2018, 01:08 PM   #4
Paul King
Paul King's Avatar
Just checked the starter bolts. They seem like the right length. Great idea though!!!
Old 08-16-2018, 01:09 PM   #5
1931 flamingo
1931 flamingo's Avatar
Cam thrust plunger??
Paul in CT
Old 08-16-2018, 01:11 PM   #6
Paul King
Paul King's Avatar
Also checked the front engine mount and that seems clear. Also a great idea! I will lubricate the distributor
Old 08-16-2018, 02:27 PM   #7
Paul King
Paul King's Avatar
John CT you are a genius...I backed out the upper inside bolt on the starter and the squeal disappeared. Thank you..Thank you...Thank you!!!
Old 08-16-2018, 03:57 PM   #8
JOHN CT
JOHN CT's Avatar
Your welcome. Finding that problem would have put a smile on my when I backed out that bolt!
Happy to help thatís why we are here
31 Tudor
66 Bonneville
Old 08-16-2018, 04:07 PM   #9
Marshall V. Daut
Great! Easy fixes are always welcome around here!
If that starter mounting bolt had been a tad longer, the engine might have been difficult to turn over, as it would have been pushing harder against the flywheel. Such a situation has fooled a great many Model A guys over the years into thinking the engine was stuck. I believe your squeal would have gone away in short order because the turning flywheel would have worn down the end of the softer metal bolt shank. As you press in the clutch, the crankshaft moves forward a little bit and that would have also contributed to ending the sound by spinning with more force against the bolt end. 'Sure would have been unnerving until the bolt wore down, though!
Marshall
