Old 06-12-2018, 07:30 PM   #1
patbill@megahits.com
Smile 48 mercury sits low at rear
Hi Fordbarners,
I have a 48 Mercury convertible that sits low at the rear. Before I got the car, it had airplane type shocks installed all around. It has the original rear spring, still wrapped in metal shielding. I'm sure the spring is sagging due to age and wear. Is getting the spring re-arched my best bet? Are new rear springs available? I don't see them in any of the catalogs. Has anyone tried air shocks or shocks with coil springs on a 46-48 Ford or Merc.? Any ideas on the best way to raise the back of the car an inch and a half or two inches. Thanks for your input.
Bill in Connecticut
patbill@megahits.com is offline   Reply With Quote
Old 06-12-2018, 09:46 PM   #2
Clem Clement
Clem Clement's Avatar
Default Re: 48 mercury sits low at rear
Carpenter had original front springs for my 39 pickup
Old 06-12-2018, 10:27 PM   #3
19Fordy
19Fordy's Avatar
Here's one for sale on Ebay. Contact the seller and ask for the part number, the number of leafs, any broken leafs etc. Eaton spring company can make you a brand new spring. Also, contact Posie's.
https://www.ebay.com/itm/35-36-37-38...kAAOSwsExa~cxO
Old 06-19-2018, 06:02 PM   #4
Thanks for your help!
Bill in Conn.
Old 06-19-2018, 06:28 PM   #5
Pete
Pete's Avatar
There are several companies that can re-heat treat your original spring and re-arch it to stock.
I have always thought this is better than getting a new spring made from who knows what scrap steel.
Ford made his own steel and it was ALWAYS higher quality than the market stuff back in the day.
Old 06-19-2018, 06:38 PM   #6
woodiewagon46
Eaton Spring might have one.
woodiewagon46 is offline   Reply With Quote
Old 06-19-2018, 06:50 PM   #7
Paul Bennett
Yep, too low at rear
Paul Bennett is offline   Reply With Quote
Old 06-19-2018, 07:54 PM   #8
Ford46
Ford46's Avatar
The 41-48 Ford and Mercury cars always sat higher in the front than the rear. Of course there can also be issues that cause it to sit lower than normal. LouB.
Ford46 is offline   Reply With Quote
Old 06-19-2018, 08:33 PM   #9
Charlie ny
p/b,
Perhaps looking local might work too. I talked to the boss man at the county
high way garage when I needed some spring work done. In our area , much bigger than lovely Sharon, there are a few spring shops. The boss man recommended the place he takes the counties work to and they did a great job. The guy at the shop "got it" .....rounded the ends and tapered the tips.....my spring was wrapped too and once the wrapping was removed we found two broken leaves.
Charlie ny
Old 06-20-2018, 08:35 AM   #10
TJ
TJ's Avatar
A wrapped spring can be hiding broken leaves. Pull it and have it checked.
Old 06-21-2018, 07:38 PM   #11
Thanks again for all of the input.
Bill
Old 06-22-2018, 02:07 PM   #12
grumppyoldman
grumppyoldman's Avatar
First thing I would check to see if some prior owner put longer shackles on it to make it lower. I put them on my 48 Ford when I was a kid, looked cool. Al
grumppyoldman is offline   Reply With Quote
