Old 09-07-2013, 03:10 PM   #1
waynes
Default Dual Carb Fuel Pressure?
I just installed an Edlebrock Regular Dual (Hi-rise) set-up in my 38 coupe. The manifold came from the estate of an old stock car driver who welded a 1/4 inch plate on the bottom. This made a problem with the fuel pump lever not engaging the push rod so I installed a 4-7 lb electic pump and the engine fired right up. Problem is it has a real fast idle and backfires when given more gas. Should I install a pressure regulator or is there some other solution? Thanks.
waynes is offline   Reply With Quote
Old 09-07-2013, 03:24 PM   #2
ford3
Default Re: Dual Carb Fuel Pressure?
4 to 7# is to much pressure, 2 to 2 1/2# is all that is needed, any more and you can have a carb flooding problem. is it back firing out carb or tail pipe? most likely a stuck valve causing that
ford3 is offline   Reply With Quote
Old 09-07-2013, 03:43 PM   #3
my4dv8
Yes about 3x too much. A lower pressure pump would be better along with a suitable 2 to 4 lb regulator , I think Holley blue , but there are others also. Though the round dial type ones are notorious for irregular pressure. So at present you are probably lifting the needle valve off the seat and flooding the carb. Fix the fuel pressure first , the evaluate other issues.
my4dv8 is offline   Reply With Quote
Old 09-07-2013, 07:18 PM   #4
russcc
Using the right Facet electric pump, there is no need for a pressure regulator as they self regulate to the pressure range you select. One source is Aircraft & Spruce. Thay are made in USA in NY by Purolater. Their tech people can help you pick the right pump for your application. About $35.oo.
Old 09-07-2013, 07:21 PM   #5
Bluebell
I have read that 1 backfire is enough to damage you power valve. You may well have other issues as well, but you fuel regulator set for 2 1/2 psi is the first step.
Bluebell is offline   Reply With Quote
Old 09-07-2013, 09:08 PM   #6
41ford1
41ford1's Avatar
2 1/2 to 3 PSI is more than adequate. A stock FP will feed two carbs with out a problem. Get rid of the electric pump and shim the push rod a 1/4". If it backfired through the carbs you may need to replace the PVs.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 09-08-2013, 07:54 AM   #7
waynes
Thanks to all for input. I ordered a Holley low PSI regulator. I'd like to go back to the mechanical pump and keep electric for backup and intial start up but not sure how to shim the push rod recommended by 41Ford1. Would appreciate input on that.
Thanks again.
Old 09-08-2013, 01:43 PM   #8
Roger/Sacramento
Roger/Sacramento's Avatar
I have a new stock mechanical pump which is supposedly around four lbs. pressure and an electrical backup which is rated at four lbs. Don't use a regulator and my three 97's don't leak.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 09-08-2013, 01:45 PM   #9
ford3
rather than shimming, find out how long you want the push rod, right down the length, then braze up the end of rod, file it round so it fits in the push rod hole, then measure rod length, file it to length, ive done that on a lot of my flat head valves when i used a reground cam in my race cars, now i just use chevy valves they are longer
Old 09-08-2013, 03:10 PM   #10
flatjack9
flatjack9's Avatar
Thanks again.
With the correct length stock pushrod, there is no reason for any shimming.
Old 09-08-2013, 05:59 PM   #11
Mike in AZ
Mike in AZ's Avatar
might think about pressure gauge to check pressure from regulator.....Mike
Mike in AZ is offline   Reply With Quote
