Old 09-14-2019, 07:59 PM   #1
d.
Default battery power loss mystery
I have a 6v NAPA commercial battery which I have maintained on a 6v maintainer charger...the battery is on the bench.
It has read 6.7v. for months; suddenly yesterday it read 4.3v.
I unhooked it and let it sit a day and repowered it...still reading at 4.3v.
What is going on ?
Did the battery just drop a cell overnight?
How would that happen?
all suggestions welcome.
thank you.
d. is offline   Reply With Quote
Old 09-14-2019, 08:07 PM   #2
Magicbox51
Magicbox51's Avatar
Default Re: battery power loss mystery
Maybe the charger is at fault or the connection to the battery. I would check those first. Also, check the electrolyte in the battery cells.
-Bill G
Magicbox51 is offline   Reply With Quote
Old 09-14-2019, 09:38 PM   #3
Patrick L.
Patrick L.'s Avatar
What does 'repowered it' mean ? If it means you recharged it, did the charger show full charge ? When on the charger does one cell bubble more than the others. It may be time to take a hydrometer reading. Have you checked to see if something is drawing down the battery ?
Old 09-15-2019, 07:49 AM   #4
DHZIEMAN
No mention of the age of the battery. It appears you have one cell not taking a charge or ???? Your voltage is down just about one Cells worth. Older batteries due tend to fail!
DHZIEMAN is offline   Reply With Quote
Old 09-15-2019, 08:50 AM   #5
Standing Elk
I just had to replace my battery for that same reason.
Standing Elk is offline   Reply With Quote
Old 09-15-2019, 10:34 AM   #6
jrelliott
jrelliott's Avatar
You have a shorted cell in the battery. Time to get another battery. What happens is either there is a piece of one of the plates touching the other plate or the plates have warped coming in contact with the two plates in the battery. This condition can happen if you run the battery out of water, charge or discharge the battery at a high rate.
Old 09-15-2019, 04:46 PM   #7
d.
Patrick, "repowered" means I re-plugged the charger into the wall after disconnecting it for a day.
The battery is on the bench, so no draw down, cells are full and always have been, connections are clean, no sudden discharge.
It just seems weird that overnight it went from 6.7v to 4.3v just sitting on my workbench.
Old 09-15-2019, 06:07 PM   #8
Patrick L.
Patrick L.'s Avatar
OK, I didn't know the battery was sitting on the bench. I'd still check each cell with a hydrometer, but, it seems like a cell is bad and the battery is now defective.
Old 09-16-2019, 07:28 AM   #9
eagle
eagle's Avatar
First off, try another charger for a few hours. If voltage comes back up, then there's a possibility it may still be ok. Chances are though, it likely needing replacement. Some maintainers run too high of a float but yours seems fine at 6.7V. I have had maintainers catch fire. However, I do run trickle chargers on batteries that sit unused a lot, although I hook them up for about 6 hours every few months, then disconnect them.
Old 09-16-2019, 09:24 AM   #10
chap52
chap52's Avatar
Use to be able to take batteries to an auto parts store and have them "load test" them for free. However many stores have gone digital and their fancy tool won't read a 6 volt battery. Hydrometer's are still available, even at Walmart or Amazon. Chap
https://www.walmart.com/search/?cat_...ery+hydrometer
Old 09-16-2019, 09:30 AM   #11
Mulletwagon
The low cost hydrometer test is the way to go. Suspect one cell will show less floating balls than the rest which will indicate a bad cell.
Mulletwagon is offline   Reply With Quote
