Old 09-05-2019, 07:57 PM   #1
hope
hope's Avatar
Default bleeding brakes
1940 tudor.
Here i am again, still chasing brake trouble. Its getting too much for this old man........
Bled the rear brakes o.k. with no bubbles, so on to the right front and the "bleeding screw is loose" upon just cracking open, so its letting air in the clear bleeding tube to the bottle.
Front cylinders are NEW (most likely Foreign made).
Question is: where can i get good ones?
Hope
P.S. Have to leave it alone for a while, because of so much frustration.
hope is offline   Reply With Quote
Old 09-05-2019, 08:44 PM   #2
Ronnieroadster
Ronnieroadster's Avatar
Default Re: bleeding brakes
Originally Posted by hope View Post
1940 tudor.
Hope
Go to your local NAPA store and have them order you new WAGNOR brand wheel cylinders last ones I got were USA made and excellent quality.
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder and Driver of the First Ford Flathead bodied roadster to run 200 MPH Record run July 13, 2018 LTA timing association 200.921 from a standing start in one and a half miles burning gasoline.
Old 09-05-2019, 08:49 PM   #3
Tim Ayers
I noticed Kantner Auto Parts in Booton, NJ is listing US made Wagner brake cylinders for Fords as well.
Tim Ayers is online now   Reply With Quote
Old 09-05-2019, 09:30 PM   #4
Fairview
If the problem is loose bleeders, try speed bleeders. They have a one way check valve for easy bleeding, and a sealer on the threads. Used a pair in the front wheel cylinders today and worked well. The pair were about $13 at Advance Auto.
Fairview is offline   Reply With Quote
Old 09-05-2019, 10:20 PM   #5
hope
hope's Avatar
Thanks for the reply, but i have speed bleeders and they are also loose.
Old 09-06-2019, 04:43 AM   #6
Mart
Mart's Avatar
Bleed screws are always loose. There should be no point in the bleeding process where you are sucking on the cylinder.
You should always close the bleeder before letting the pedal come up again.
Use a pressure bleed system or a vacuum setup.
You can get grease that is compatible with brake rubbers. You can use that to help a bleed screw not leak if using a vacuum device.
If you can get a helper, the old fashioned 2 person method is as good as any, once partially filled.
One question. Could the bleed screws be loose because they are 3/8 fine and the holes are 10mm x 1mm? Never know with some modern repro stuff.
Mart.
Mart is online now   Reply With Quote
Old 09-10-2019, 09:02 PM   #7
fortyfords
fortyfords's Avatar
I always remove the bleeder and wrap the one I'm bleeding with Teflon tape; don't screw it all the way in until you are done bleeding. I always hold the bleed tube so it goes up and these two things really work good when you are using vacuum to bleed. Then I go to the next bleeder and do the same thing over again.
fortyfords is offline   Reply With Quote
Old 09-10-2019, 09:39 PM   #8
Tinker
Tinker's Avatar
Anyone use the "reverse" brake bleeders?
https://www.harborfreight.com/brake-...hoCKE0QAvD_BwE
I do it regular way with someone pumping the brakes. Just curious
Old 09-10-2019, 10:31 PM   #9
Talkwrench
Talkwrench's Avatar
Yeah tried one of those pumps... But the simplest thing Ive ever done was put speed bleeders in. If its a single circuit system dont push the pedal all the way to the floor! I found just slow steady pumps and even just holding the pedal down for a period of time, if its a new bleed.
Old 09-11-2019, 06:38 AM   #10
51 MERC-CT
51 MERC-CT's Avatar
1940 tudor.
Hope
Just a thought, if foreign made it may be possible that these are made with metric threads (10mm x 1) pitch.
They are just slightly bigger than the 3/8" dia. standard ones that are used.
The 3/8 x 24 threads easily into the 10mm x 1 nut but is loose.
51 MERC-CT is online now   Reply With Quote
Old 09-11-2019, 01:32 PM   #11
hope
hope's Avatar
I doubt this to be the case, but in any case my next attempt will be to isolate the front from the back lines alternatively to see if the master cylinder will activate just the front or the back.
Old 09-11-2019, 07:23 PM   #12
1948F-1Pickup
1948F-1Pickup's Avatar
I'm thinking..... just like Mart says, pressure bleed it.
Couldn't be too hard to tap a small hose nipple into the
master cylinder cap and put about 10 psi of air to it.
(Just don't let the master cylinder run dry) Replace the
fitting with a plug when you're done.
1948F-1Pickup is offline   Reply With Quote
Old 09-11-2019, 09:17 PM   #13
hope
hope's Avatar
Unhappy Re: bleeding brakes
Yes, thank you.
Old 09-11-2019, 10:40 PM   #14
cas3
no fancy gizmos, and no help. i just start a the bleeder that farthest from the mc, study your plumbing, and jamb a stick against the seat or steering wheel if the body is intact, or hold the pedal down with a bungi cord if you are dealing with a bare chassis. its really not a big deal, been done for nearly a century without any extras
Old 09-12-2019, 12:25 AM   #15
hope
hope's Avatar
That's the way i've always done it, but for some reason its not working for me this time.
I probably have defective equipment, so i'm leaning towards starting from scratch, when i get my brain straighten out, at 83 my decisions are slow in coming.
Old 09-12-2019, 01:30 PM   #16
38bill
38bill's Avatar
FYI: I struggled many times trying to get a hard brake pedal. Finally purchased a MityVac vacuum bleeder. It never worked very well and always sucked air past the bleeder screw so you couldn't tell what was going on. I gave up on it this last time after many hours trying to get a good bleed. I then purchased a pressure bleeder by Motive. I had a little trouble getting it to seal on the MC but once it fit tight it worked incredibly well. Pumped it up and was able to bleed all 4 cylinders on the one pressurization. Super fast and its very easy to tell when the air is purged since there are no bubbles except those in the brake line. You need the pump and an adaptor for what ever MC you have. You can even build your own as seen on utube
https://www.ebay.com/itm/401314051503
PS: I figured I'd spent the money and I would end up saving it by bleeding the brakes more often thus preventing damage to the brake system.
38bill is offline   Reply With Quote
Old 09-12-2019, 05:07 PM   #17
john in illinois
john in illinois's Avatar
I use a pressure bleeder. Pump to 10psi. Walk around to each wheel with clear bleeder hose and open until no bubbles. I usually do it twice. You never need to worry about getting air or running out of fluid in the master cylinder.
I use a C clamp to hold adapter. Other adapters available.
I see Bill has same idea.
John
File Type: jpg 5CA1175A-1F13-4EC8-8266-05DEF076523E.jpg (64.7 KB, 26 views)
Welcome each day
john in illinois is offline   Reply With Quote
Old 09-12-2019, 07:29 PM   #18
hope
hope's Avatar
YEP..........
Seem to me that's the way to go, will try to go that route when i get myself re organized.
Right now i've got some priority "honey do this" to contend with.
Hope.
Old 09-12-2019, 07:34 PM   #19
hope
hope's Avatar
Bill&John thanks for the info.
