Old 09-04-2019, 01:42 PM   #1
Jerryhamlin
Default 6 volt to 12 volt conversion
I'm converting my 1940 Ford over to 12 volt. I have the Alternater and alternater brack to flat head v8. I know Regulator is eliminated. What other engine wires go where? Gauges and lights are not an issue now. Thank you for the help.
Jerryhamlin is offline   Reply With Quote
Old 09-04-2019, 03:37 PM   #2
JSeery
JSeery's Avatar
Default Re: 6 volt to 12 volt conversion
There are several articles and old threads on doing this conversion. Here is one resource. http://www.how-to-build-hotrods.com/hot-rod-wiring.html
Old 09-04-2019, 04:14 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
As stated there are sources of information in various places.
Considering that you are using a one wire Alt. this is a general idea of the one wire hookup and the other issues that need to be addressed.
Old 09-04-2019, 04:34 PM   #4
drolston
drolston's Avatar
I left the regulator in place and just connected the Armature wire from the generator (now the +12v wire from the alternator) to the Battery terminal on the regulator. I used the former Field wire as a ground, attached to a ground point on the alternator and under the screw that fastens the regulator to the firewall on that end. The alternator should ground okay through its mounting bolts, but that added ground connection is insurance.
Old 09-04-2019, 05:15 PM   #5
19Fordy
19Fordy's Avatar
Jerry: Here's how to make your 40 Ford BAT gauge read accurately when converting to 12V and using a one wire alternator (neg. ground).. You have to isolate the BAT gauge so it operates all by itself and install a 60 OHM resister in line from the 12V input wire to the gauge. See here.
https://www.fordbarn.com/forum/showt...olt+conversion
