Old 09-03-2019, 11:41 AM   #1
1948F-1Pickup
1948F-1Pickup's Avatar
Default Underhood carnage on my F-1
Heard a loud bang this morning on the way to get gas.
Not sure what the chain of events were at a massive
2200 rpm, but the fan is missing a blade, another is
bent and the shroud doesn't look too happy either.
Radiator has some tube damage.... I'll have to look
closer at that.
If anyone has a V8 fan, V8 shroud I'd be interested.
1948F-1Pickup is offline   Reply With Quote
Old 09-03-2019, 12:09 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Underhood carnage on my F-1
Fortunately you had a shroud installed otherwise you may have had a hole in the hood
Old 09-03-2019, 12:21 PM   #3
1948F-1Pickup
Yeah..... not sure where that missing fan blade is.....
Old 09-03-2019, 12:44 PM   #4
Ggmac
It looks as if that blade was redrilled , possibly having the extra bolt holes too close to the original and fatigued the metal . I'm just going on an enlarged photo so it's a guess .
Old 09-03-2019, 01:57 PM   #5
19Fordy
19Fordy's Avatar
Please excuse double post.
Old 09-03-2019, 02:03 PM   #6
19Fordy
19Fordy's Avatar
Had that happen in 1972 when the fan blade on my 8RT flew apart going thru the hood of my 40 and into the radiator. My conclusion was that over the many years and cycles of flexing those OEM fan blades work harden, crack and break. I was standing next to the car "giving it gas" when it happened. Could have cut my head off. Installed new stainless blade and it's still going strong. Fan pulley is home made. I know there are those who say fan blade breakage is a rarity but, in this case old is not gold.
Old 09-03-2019, 03:46 PM   #7
RalphM
RalphM's Avatar
Your fan hub appears to be one of the new aftermarket ones. Did something possibly come loose with the old fan blade onto the new hub?
I’ve never had a fan break off but I did have one of the oiled style hubs pulley broken in half. It separated half of the pulley from the hub, didn’t fly off just kinda rattled around and of course the belt was doing nothing then.
RalphM is offline   Reply With Quote
Old 09-03-2019, 04:17 PM   #8
1948F-1Pickup
Iím thinking your theory is probably right on the money.
I just found the missing blade too. The break looks consistent with metal fatigue.
Old 09-03-2019, 04:46 PM   #9
deuce_roadster
deuce_roadster's Avatar
Yeah, a friend of mine with a 54 Y block had a blade come off and exit the hood. I NEVER stand in line with a spinning fan. They do work harden and break as theorized above. My 40s both have NOS fans as well as the 33. 32 5w is another story, I am thinking I should swap it out. As Chuck Yeager said "never wait for trouble".
Old 09-03-2019, 05:24 PM   #10
Bums F-1
Bums F-1's Avatar
I have a fan, bearing hub and pulley with a shroud from a 1950 F-1.
It's yours if you pick it up or arrange the shipping.
Bums F-1 is offline   Reply With Quote
Old 09-03-2019, 05:52 PM   #11
1948F-1Pickup
Yes sir...... I'd like to do that. I'm up in Modesto fairly frequently
as I have customers in Merced, etc.
I'll send you a PM.
Old 09-03-2019, 06:37 PM   #12
Ronnieroadster
Ronnieroadster's Avatar
I had the same experience on my 1950 F-1 panel truck. This was my first vehicle and a daily driver way back in 1971. Same thing heard a bang had no idea what it was until I found water pouring out from under the front of my old truck that broken fan blade was sticking out of the lower radiator hose since the truck had no fan shroud it must have saved the radiator from damage good thing since I had no money to repair anything major back then. Good thing we were not under the hood looking things over when the blade let loose. I still have that 8BA engine my first Flathead from my old F-1. Its going into my Deuce pickup one day and become my daily driver once again but its going to be modified a bit for more power. There goes the fuel economy!
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder and Driver of the First Ford Flathead bodied roadster to run 200 MPH Record run July 13, 2018 LTA timing association 200.921 from a standing start in one and a half miles burning gasoline.
Old 09-03-2019, 07:31 PM   #13
1948F-1Pickup
Ronnieroadster
Wow. I've heard from a few people now with similar stories.
I'm looking for a radiator now too..... my repo one looks like it would need a new core! Gives me a good excuse to try to find an original radiator with original tanks.
Old 09-03-2019, 07:35 PM   #14
Tim Ayers
Very cool offer!
Old 09-03-2019, 08:19 PM   #15
r_reed
r_reed's Avatar
i had one blade break off my 8ba in 1975. i was on my way to a meeting at night, i head a crash and the engine started vibrating really bad. i parked under a street light, noticed the missing blade (no leak). i slipped off the fan belt and went on my way. i found the missing blade jammed between my shroud and radiator, no damage to each. i guess i was lucky. when i heard the bang, it thought it was over for the motor.
1949 F-1 Flatrod II (flat paint, flat motor)
Keeping one more flathead alive
It smoked, but gave it up 7/26/2013
East Glenville NY
r_reed is offline   Reply With Quote
Old 09-03-2019, 09:09 PM   #16
Ross F-1
Ross F-1's Avatar
I wish someone would repro these fans, they are all a time bomb when you get right down to it.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 09-03-2019, 09:18 PM   #17
zoegrant
zoegrant's Avatar
I have heard of fan blades becoming brittle after having it chromed....really scary when you think of how many times we work on an engine adjustment leaning over the engine with the engine running...
zoegrant is offline   Reply With Quote
Old 09-03-2019, 10:33 PM   #18
51504bat
51504bat's Avatar
Just head up 101 to Paso Robles and BrassWorks. It won't be cheap but you'll get a quality brass/copper radiator made right there. Don't know about now but when I ordered the one for my '39 p/u the lead time was about 7 weeks. Picked it up the same weekend as TROG so it was a win win (except for the rain).
Old 09-04-2019, 08:18 AM   #19
1948F-1Pickup
Yup. Sent BrassWorks an email yesterday. Waiting for their reply. Looks like they can even fabricate tanks.... hopefully without originals, the ones on my radiator are the not that great generic reproductions.
Old 09-04-2019, 06:34 PM   #20
rotorwrench
rotorwrench's Avatar
My hand me down 51 Mercury threw a blade back in the late 50s. It reminded my Pop of flak shrapnel hitting the B17 over the targets in WWII. The blade left a dent in the hood that was a b!tch to get out. I keep a close eye on those damn things.
