Old 08-25-2019, 07:34 AM   #1
imacrazy
Default Charging to much
Took my s/w out Saturday for a drive, the amp meter was charging all the way over and was hot to touch ,wires also. Could this be a bad cut out or a short somewhere?
Thanks
Bill
imacrazy is offline   Reply With Quote
Old 08-25-2019, 08:54 AM   #2
burner31
burner31's Avatar
Default Re: Charging to much
Was it doing this the last time you drove it?
You could crank your third brush down, tap your cutout, replace your cutout, etc....
Hot to touch wires are a big red flag warning...take heed.
Keith
Shawnee OK
'31 SW 160-B
Old 08-25-2019, 08:55 AM   #3
Purdy Swoft
Purdy Swoft's Avatar
I would first try the simple thing like the third brush adjustment . Raise the adjustable brush in the generator to reduce charge rate , lower the brush to increase charge rate .
Old 08-25-2019, 09:14 AM   #4
eagle
eagle's Avatar
Your going to have to take some accurate voltage readings in order to make any informed decisions about what is going on. Check battery with car off, idling, and driving rpm.
Old 08-25-2019, 02:55 PM   #5
Magicbox51
Magicbox51's Avatar
If the ammeter was hot, then it might be that the connection to the ammeter is getting hot due to one of the crimp-on connectors going bad and inserting some resistance. The generator uses the current coming back from the battery to determine how much to put out. If there is resistance in the loop somewhere the generator will just keep on chugging away. It's worth a shot to check that. Such was the case with my car when I first got it.
-Bill G
Magicbox51 is offline   Reply With Quote
Old 08-26-2019, 10:01 AM   #6
Badpuppy
Ammeter post shorted to tank, likely.
Old 08-26-2019, 12:35 PM   #7
rotorwrench
rotorwrench's Avatar
Any loose connection will cause resistance. Resistance results in heat generation near the site of the resistance. Resistors get hot. Dead shorts to ground usually get way hot way fast and burn something up. It could be any connection on instrument panel or in the terminal box but it's likely close by there somewhere. Check all of them and make sure they are tight and conductor wires are in good condition.
Old 08-26-2019, 09:53 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
The stock cut out is just and on and off switch.
